500W PA amplifier with Limiter
Old 7th December 2011, 09:01 AM   #1841
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
gains for hifi amps are about x20, while professional/PA amps start at x40, i even saw a design with gains of x70....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th December 2011, 09:54 AM   #1842
wattaniya is offline wattaniya
hi apex sir,
can i use c5171,a1930 or c4793,a1837 instead mje340,mje350 for pre driver section.
if its ok so is it need small heatsink or no need heatsink.
Old 7th December 2011, 01:16 PM   #1843
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
Yes, and use very small heatsink.
Old 7th December 2011, 01:36 PM   #1844
thanks sir for the reply.
Old 7th December 2011, 04:35 PM   #1845
comasus is offline comasus  India
Replace R2, use 1k instead 10k and gain will increase.
If R22(680) decreased bias decreases or not?
Can I use 3mm led in place of NSL32?
Old 7th December 2011, 08:47 PM   #1846
apexaudio's Avatar
Yes and yes, you have 'clip' led and amp without limiter.
Old 8th December 2011, 02:32 AM   #1847
Thank you sir for your reply
Old 8th December 2011, 02:12 PM   #1848
yohnsee is offline yohnsee  Hungary
@ JOHN BALI:
Very nice design! I also wanted to build my B500 with TTA and TTC transistors, but they are unavaiable here
I like to get my hands on those trannies, their advantage is that their case is full plastic (even their heatsink side)
The bird is the word...
Old 16th December 2011, 02:42 PM   #1849
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Originally Posted by yohnsee View Post
@ JOHN BALI:
But finally I made it with 2SA & 2SC
I keep those TTA & TTC because maybe it not as good 2SA & 2SC
note that TTA & TTC is new product, maybe replacement for 2SA & 2SC
the back of those TTA & TTC are metals, not full plastic case
that make a little doubt, maybe it fake or not that good older version
I'm also happy if I can find full plastic case, so we can mount it easier
Btw thanks, my PCB is not good there are miss-route on it
on it IC's pin 1 & 3, sorry not fix that yet
Thank you, I wish you happy
peace & G B U
Old 18th December 2011, 12:18 AM   #1850
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 500W PA amplifier with Limiter
Hello mile can i ask if it is possible to use 85vdc+/- on B500 do i have to change anything any modification?
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3611 Yesterday 08:49 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
