500W PA amplifier with Limiter
Old 21st November 2011, 08:20 AM   #1811
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default APEX D500
D500 class D PA Amplifier output stage.
Old 21st November 2011, 08:28 PM   #1812
jlcastro77 is offline jlcastro77  Philippines
hello apex, im planning to build b500 - stereo for church PA system. i need something that can drive 4 boxes with 12 inch drivers. any comment on this? tnx
Old 21st November 2011, 09:27 PM   #1813
apexaudio's Avatar
What power is your 12 inch speakers?
Old 21st November 2011, 09:47 PM   #1814
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
how big is your church? multi speaker arrays using smaller drivers, 4inches say, can work here.....
be ready to use 100volt distribution system......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st November 2011, 10:33 PM   #1815
power of the woofers are 400-450 watts... haven't build the enclosures yet... woofers or instrumental speakers... any recommendations of horn type enclosures? im planning to have 4 of something like this Pair Dual 12" PA Speakers | 12 Inch DJ Loud Speakers | Dual 12" Band Speakers | Dual 12" Karaoke Loud Speakers | Dual 12" Church Speakers
Old 21st November 2011, 10:36 PM   #1816
hello sir tony the church is not that big... i think its like 3 basketball courts in size. thanks!
Old 21st November 2011, 10:37 PM   #1817
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 500W PA amplifier with Limiter
for church mostly they use PA/instrumental
speakers
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 21st November 2011, 11:28 PM   #1818
thanks irvynejay... i'll take note of that. 12 inch instrumental speakers (TARGA) cost about 22USD
Old 22nd November 2011, 02:50 AM   #1819
TonyTecson's Avatar
it is big.....distributed system is the way to go, otherwise sound distribution may not be uniform and you run risk of dead spots.....are you mounting those speakers overhead?
Old 22nd November 2011, 09:55 AM   #1820
yes sir tony... it will be mounted overhead. one thing am planning to do is to make two of the speakers active... the other two will be on a passive mode and will be connected in parallel with the active one... any recommendations? i believe 1 b500 of sir apex can handle 2 12 inch instrumental speakers right?
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
