500W PA amplifier with Limiter
B500 Protect PCB...
Protect PCB for B500...
To masters
I found this pcb from internet. I converted from pdf to lay6.But my experience not enough to build and I did not to be sure,it is true or not. therefore I'am asking to masters. İf it is possible please can you check it
sorry for my bad english
Yes, D3 must be inverted as you can see in Apex components PCB.
A nasty PCB, without numbered parts ... could be better. However, the schematic should be in correlation with PCB.
A nicer PCB is the one posted by @student II although the distance between PCB tracks should be checked there!!!
Regarding the schematic, you would need a resistor or jumper between SGND and GND, very useful especially if we want to test only PCB amplifier.
Fuses should protect all the amplifier. I'm saying this because in my experience I had customers who have dropped cognac inside the amplifier - through the air vents of the casing - and so there was a short circuit in the VAS circuit. The lack of fuses to interrupt this was useful because it limited the damage. So you never know who you sell your amplifier !!! There are rare cases, but they can exist!
podrias compartirme por favor el pdf, porque yo lo arme y no me funciono, me pregunto en que me habre equivocado
Ola yo poderia hablar castelhano pero esto es un english forum, so you should speak in english. I gona send tou you information about B500P.
  • Apex B500P Foto A.pdf
  • Apex B500P PCB.pdf
Javys, debes escribir en Inglés o los Miembros del Foro no pueden ayudarte.
Es un Foro Internacional, hay miembros de todos los países e idiomas, han convenido en usar Inglés como idioma común.
Si no sabes Inglés usa Google Traductor o algún otro.
No es perfecto pero peor es nada. :D
Note to Moderators: don´t waste time translating, this is only a suggestion for Javys to use Google Translate or something, both ways :)
EDIT: thanks Kandimba, muito obrigado :)
De nada, hombre. :)
Regadrs
Hİ friends,
can any one tell me pls what is different with B500 and B500p? i start pcb but i like make my own. but now i see there is another pcb B500p just a little bit different from B500. please some one explane this.
i just finish my pcb desing but not check if there is a anything wrong. in 2 days i will start make my B500. ty to apex for share it.
Hİ friends,
As you can see in Post #3432, you have VI limiter as well as Prot. detection to activate PSU 7 Protection, and you have more: Led indication for ON, Signal and overload.
