500W PA amplifier with Limiter
Old 23rd April 2011, 06:13 PM   #1501
yosie48f is offline yosie48f  Indonesia
Originally Posted by nazirdigi View Post
hey man is this h900 or b500? wrong thread.
I am sorry, i took this layout on this thread post #598. And just want to say Thank You to Mr. Mile who gave me VALUABLE things. once again i'm Thank You so much Mr.Mile.....Regards
yosie48f
Old 23rd April 2011, 07:50 PM   #1502
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
apex sir thanks for ur reply.
without power transistors can i give dc 80v to check b500.
what are the main places to check the voltages.
dc offset below 100mv. is it ok?
Use 10ohms resistors instead fuses and test amp with outputs transistors.
Old 25th April 2011, 06:33 AM   #1503
drowranger is offline drowranger
Originally Posted by apexaudio View Post
This is simple XLR input circuit.
I suggest to use 2 way x-over with XLR input, and 3 position switch to select input mode (subwoofer, satelite or full range)
can you give me the foil pattern of the xlr input circuit?
thanks,
joel
Old 25th April 2011, 05:25 PM   #1504
wattaniya is offline wattaniya
hi apex sir.
is it 10ohm resistor 1/4 watt or 1watt?
Old 26th April 2011, 03:08 AM   #1505
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
i think u can use 5Watts....
thank u.....
Old 26th April 2011, 05:19 AM   #1506
manidecibels is offline manidecibels  India
Smile hi iam mani from banglore...
i want design apex 500 amp pcb do u want ?
you have to share the designing cost....
let me know , call me on +919742775526
Old 27th April 2011, 03:54 AM   #1507
ariyanto is offline ariyanto  Indonesia
ariyanto's Avatar
hello apex sir
for stereo can i use this psu for b500 with 55v,0,55vac?
How to lay out the size?
regards
Old 27th April 2011, 11:53 AM   #1508
B500 based on schematics of H900, but in AB class.
Power supply +/-90Vmax.
why did you suggest 60vac when its output is only 83v and you suggest for 55vac for safe reason.randy sloan amp is only 85 vdc and its ratings is 550w at 4 ohms and consist of 12 mosfets and yours is only 8 transistor .are your ratings at your amp which is 500 watts is true?can it handle a 90 volt dc like you posted here?i have built randy sloan amp which is optimos and it is very durable and very stable.and its rating is 250w at 4ohms and its power supply is 72vdc.its output has 4 mosfets or 2 pairs and by the way this is another amp im talking different from the one i mentioned first.
Old 27th April 2011, 02:57 PM   #1509
regards
hi ariyanto
did u find the pdf file of this ?
if u found, then directly open in adobe illustrator or photoshop, then print.
if u open in photoshop then give the resolution to 300dpi and choose grayscale., and choose transparent background thats it.
Old 27th April 2011, 03:03 PM   #1510
R.I.P.
You seem to be the only poster who considers claims at their face value and rightly queries "facts" that might be fiction.
This thread and others have attracted a load of Members who look at the power ratings through rose tinted spectacles, or welding helmet with the 11 filter down and say "I want some of that!!"
regards Andrew T.
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
