500W PA amplifier with Limiter - Page 15 - diyAudio
Old 23rd April 2010, 12:54 AM   #141
eesbiboi's Avatar
engel,
sir if i'd be constructing this amp, how much would it cost me only for the parts on the main pcb with the power transistors on it???...
Old 23rd April 2010, 03:42 AM   #142
around 1k mono board only no psu
the psu cost higher
Old 23rd April 2010, 05:47 AM   #143
Originally Posted by apexaudio View Post
If you like sound of B500, but is to much powerfull for Hi-Fi, consider about this 50W amp.
how about 100w hi fi
Old 23rd April 2010, 06:02 AM   #144
I hope this forum help you to learn more English, and more about electronic,
Thank you very much and God bless you
I respect both know sincerely
Old 23rd April 2010, 08:49 AM   #145
apexaudio's Avatar
For about 120W/200W, 8R/4R use B500 pcb with two pair outputs on +/-60V rail voltage.
Old 23rd April 2010, 09:43 AM   #146
bulb is very bright during first power
after the in rush current
bulb start to dimmed
with the power still on and the bulb dimmed, start checking that the circuits are operating correctly.
What is the voltage on the supply rails?
What is the voltage across the output, both DC and AC.
What are the currents flowing in the LTP pair, are they matched?
ETC........
When you are sure all is operating correctly and that nothing is overheating, then it's time to plug straight to mains power.
It will probably blow the mains fuse and maybe the supply rail fuses as well.
Go build a timed relay bypassed soft start circuit to save fuses.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd April 2010, 11:53 AM   #147
apexaudio's Avatar
ETC........
I hope that some basic measurement was already done.
Old 23rd April 2010, 12:30 PM   #148
wg_ski is offline wg_ski  United States
It takes more than one short plug in on the light bulb before I'm confident enough to throw the switch on it. Initially set the bias so the output stage is barely cracked open and make sure music plays. And that you get graceful dropping of the mains and graceful clipping as the bulb gets brighter. Then set the bias high (maybe 100mA in the output stage) and let it idle for an hour. make sure it doesn't run away. Then go back and re-check everything, re-set the bias to a milliamp or two - and then run it without the limiter.
And when you first fire it up, the first thing you do is check bias stability. Set it to target, and see where it goes after the first hour. If all is well, hook up a dummy load. Parallel the dummy load with a speaker in series with 1k ohms (so you can hear what's going on but not at ear splitting level). Then clip the snot out of it with test tones and music. This is a good time to measure power at 20 Hz, 20KHz if you desire, and hear what it sounds like when you drive it hard. If it takes *this*, then it's ready for serious listening tests.
Old 23rd April 2010, 12:48 PM   #149
apexaudio's Avatar
There is no bias adjust on this circuit.
Old 23rd April 2010, 01:08 PM   #150
that's where we fundamentally disagree.
I will not plug in speakers to an untested amplifier.
I will not remove the input shorting link until I know that all the operating quiescent currents are as expected.
I will not set the quiescent output stage current (bias) with the output loaded nor with the input shorting link removed nor when the PSU voltage is below the normal operating voltage, i.e no bulb tester in the primary feed.
regards Andrew T.
900W H-class PA Amp with Limiter apexaudio Solid State 3536 Yesterday 02:21 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
