500W PA amplifier with Limiter - Page 142 - diyAudio
Old 28th March 2011, 07:31 AM   #1411
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Originally Posted by viki_v2 View Post
Check the pics and guide.
The sound is very low and distorted.
The resistor 0r22/5w in front of 2sa1943 on psu board got burnt .
My psu 24-0-24 before rectification, after rectification 37-0-37.
Old 28th March 2011, 07:36 AM   #1412
viki_v2's Avatar
Originally Posted by irvynejay View Post
I can't see input ground to PSU did you follow this?
Yes i followed the diagram. connected the psu gnd , input gnd and out gnd at a common point on gnd next to out
Old 28th March 2011, 08:54 AM   #1413
viki_v2's Avatar
voltage on negative terminal drops to 20v, after connection to b500.
positive voltage is proper at 37v.
Old 28th March 2011, 09:24 AM   #1414
aman khalsa's Avatar
call me bro...09872589611
Old 29th March 2011, 10:33 AM   #1415
mihailo is offline mihailo  Serbia
Hi Apex. i have a problem with your amplifier.
It all looks ok when connect him, and play song. But when volume reachs half, speaker starts broming(brrrrrrrr) very loudly. I turn off amplifier, reduce volume and and turn again on, and all looks again ok. Where is the problem? Please help me!!!!!!!
Old 29th March 2011, 10:36 AM   #1416
AndrewT is online now AndrewT  Scotland
could it be Low Frequency instability of the PSU to amplifier interaction? Used to be known as "motorboating" in valve amplifiers, because that is what it sounded like.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th March 2011, 11:13 AM   #1417
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
did you test MJE340/350 and 2n5551,5401 unmount it on the pcb then test it with multimeter
Old 29th March 2011, 01:15 PM   #1418
viki_v2's Avatar
I tested them, seem to be ok.
I changed 5401 near -90v . The problem of voltage drop is solved. Equal voltages on both terminals.
Psu is also stable and fine no burning , no heating of any parts.
Still no sound.
No current on out.
Old 29th March 2011, 01:19 PM   #1419
U use 33E or E33 for emitter?
Old 29th March 2011, 01:32 PM   #1420
I think you mean 33E = 33r = 33ohm resistor.
If that is the case, then E33=0r33 = zero point three three ohm resistor.
Do not drop the leading zero. It is important to accurate transfer of information.
regards Andrew T.
900W H-class PA Amp with Limiter apexaudio Solid State 3537 28th May 2017 04:58 PM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
