500W PA amplifier with Limiter 500W PA amplifier with Limiter - Page 14 - diyAudio
Old 22nd April 2010, 08:23 PM   #131
engel dela pena is offline engel dela pena  Philippines
Originally Posted by eesbiboi View Post
engel,
sir what components are hard to find in our country???...your from what city???...
b500 is friendly here unlike the h900,
no IR2117
nsl32 also,
i'm from malolos,
but i got most af the parts also from manila
Old 22nd April 2010, 08:30 PM   #132
Originally Posted by apexaudio View Post
Bulb have positive temperature coefficient (PTC). When bulb is cold it have small resistance, when current rising bulb get hot and resistance is R=U2/P. U=220v, P=100w and R=484R when bulb bright, that resistance will drop voltage on primary and protect amplifier if something is wrong.
Resistance of 150R will drop voltage on primary if current rising. Voltage on primary will be U=220v-150RxI(A), voltage drop will protect amplifier is something was wrong also like bulb.
bulb is very bright during first power
after the in rush current
bulb start to dimmed
Old 22nd April 2010, 08:38 PM   #133
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
When during first power, caps are charging and current is high.
Old 22nd April 2010, 08:46 PM   #134
Gitsa is offline Gitsa  Moldova
Here are the details in Atach
Old 22nd April 2010, 09:14 PM   #135
apexaudio's Avatar
Thanks, I like case, it is more robust than NSL32.
Old 22nd April 2010, 09:26 PM   #136
Not had to deal with NSL32, I can not say anything, but people did on aor124, it is in kliplimiter in amplifiers, working chetko.Ya now finish your payment b500 and check!
Old 22nd April 2010, 09:39 PM   #137
Here's a similar example!
Old 22nd April 2010, 10:18 PM   #138
apexaudio's Avatar
Look like AOR124 is perfect for B500, if pins layout is right, but that will be smal problem.
Old 22nd April 2010, 10:40 PM   #139
apexaudio's Avatar
rock soul & jazz
good sonics
Like me,
Cheers
Old 22nd April 2010, 11:00 PM   #140
apexaudio's Avatar
Default Apex b50
If you like sound of B500, but is to much powerfull for Hi-Fi, consider about this 50W amp.
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3547 Today 01:57 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2017 diyAudio
