500W PA amplifier with Limiter - Page 135 - diyAudio
Old 26th February 2011, 12:58 AM   #1341
Hi Miles....
for one pair of output and dc voltage + / - 40v, what are the changes?
thank you sir
Old 26th February 2011, 12:40 PM   #1342
to check the amp in full volume without speakers using 500w bulps in amp out is it correct?
Old 26th February 2011, 12:53 PM   #1343
apexaudio's Avatar
No, use resistors for shunt on output for test. Bulps is NTC resistor ( 0,1R cold and 2,8R when light at 12V for 50W bulp), useless and danger to connect on amp out exsept in series with speaker for protect.
Old 26th February 2011, 12:55 PM   #1344
apexaudio's Avatar
Originally Posted by Noerhakim View Post
Hi Miles....
thank you sir
Use 1k/2W instead 2k2/2W for R24 and R25.
Old 26th February 2011, 12:58 PM   #1345
in the pcb there is r24 and r25 4.7k/2w resistor why is that.
Old 26th February 2011, 01:00 PM   #1346
how many watts of output?
Old 26th February 2011, 02:42 PM   #1347
apexaudio's Avatar
4k7/2W is only for test with +/-90V rail.
Old 26th February 2011, 02:42 PM   #1348
apexaudio's Avatar
120W/4R with +/-40V DC
Old 26th February 2011, 02:48 PM   #1349
I plan to use this circuit for powered speakers, 3 pairs of outputs for low and one pair of outputs for high (8 ohm speakers)
Old 26th February 2011, 04:00 PM   #1350
120W/4r tells you a channel can drive a 4r0 load to 120W.
If you attach a group of speakers to that one channel then the effective impedance of the group of speakers must not be less than 4ohm.
regards Andrew T.
Sent from my desktop computer using a keyboard
900W H-class PA Amp with Limiter apexaudio Solid State 3537 28th May 2017 04:58 PM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
