#1331 |
Use +/-55V rail and 1K5/2W instead 2k2/2W for R24 and R25.
http://www.facebook.com/APEXaudio.MileSlakovic |
#1332 |
for my opinion clipping means regulates the input signal from the amp am i correct?
if wrong pls explain. |
#1333 |
#1334 |
is this correct?
#1335 |
Yes, just 22k from overcurrent detect connect to used 0.33R/5W, +/-50V no changes for single pair.
#1336 |
#1337 | |
L Z1: 14,2V L Z2: 14,4V L R20: 446mV L R21: 440mV R Z1: 14,7V R Z2: 14,3V R R20: 444mV R R21: 438mV I used matched transistors (from the same series, and they were chosen from 15's batch with multimeter's HFE) and i used the closest possible values. When i connect signal gnd to power gnd every reading is just fine (7-8mV offset on both panels) the 300mV offset only occours when the input pins left floating or the signal gnd is not connected to power gnd. If it is a solution, to connect them together, then it will stay in this state.
The bird is the word... |
#1338 | |
#1339 |
Hi Miles....you mentioned that you were going to add these three things, are you redesigning the B500 pcb....I have added the indicator leds to my personal version of the pcb, but would like to see what your design comes out like...it is getting a bit too much for me to modify now, but I do like the XLR input stage you added a few days ago, it makes a lot of sense and actually saved me another board that had a preamp on it...less is better..still waiting to see how you will redesign the B500 to become a BX500.....
#1340 | |
Soon i will post pictures of the complete amp.
| 900W H-class PA Amp with Limiter | apexaudio | Solid State | 2542 | 22nd May 2013 06:51 AM |
| 500w power amplifier | juneray | Solid State | 70 | 16th September 2011 04:05 PM |
| 500W Power Amplifier | JRdGreat | Solid State | 24 | 16th September 2009 09:48 AM |
| 500W Aleph Amplifier? | lscangus | Pass Labs | 20 | 19th November 2005 08:29 PM |
| Looking for 300-500W amplifier | audioPT | Solid State | 3 | 31st August 2002 12:39 PM |
