#1311 | |
#1312 |
I speak a different language. Someone else help !
#1313 |
Volume pot
http://www.facebook.com/APEXaudio.MileSlakovic |
#1314 |
for the maximum power which transistor is good-mjl4281 ,mjw3281 ,2sc5200.
#1315 |
#1316 |
A, B pins are for bridge no for balanced input, go to post #54.
#1317 | |
not this bridge, but i mean balance input using one channel only grnd,a,b |
#1318 |
A and B pins can not be use as balanced input without change schematic.
#1319 |
B500 with balanced input, volume pot and bias adjust.
#1320 |
thanks apex,
the zy15 and zf15=is it ok to use for this two value boyh 1watt? the 25v 2.2uf,47uf,electrolytic=is it ok to use higher v with same uf? |
| 900W H-class PA Amp with Limiter | apexaudio | Solid State | 2542 | 22nd May 2013 06:51 AM |
| 500w power amplifier | juneray | Solid State | 70 | 16th September 2011 04:05 PM |
| 500W Power Amplifier | JRdGreat | Solid State | 24 | 16th September 2009 09:48 AM |
| 500W Aleph Amplifier? | lscangus | Pass Labs | 20 | 19th November 2005 08:29 PM |
| Looking for 300-500W amplifier | audioPT | Solid State | 3 | 31st August 2002 12:39 PM |
