500W PA amplifier with Limiter
Old 26th December 2010, 11:21 AM   #1131
wattaniya is offline wattaniya
can someone post dc protect pcb for b500.
Old 26th December 2010, 06:45 PM   #1132
b500 power supply added another pair is this ok for 4pair of outputs.
can i use other power supply,protection,soft start for b500. is this power supply for stereo.
File Type: jpg APEXaudio Reg Amp PSU adding another pair for b500.jpg (187.6 KB, 1801 views)
Old 27th December 2010, 08:00 AM   #1133
teslar is offline teslar  Thailand
Originally Posted by aman khalsa View Post
nothing is happening my dear i use 5200-1943 as drive because i have no 15032-33.
so u can use 5200-1943 its simple.
nd there is a mistake in pcb i show as a blue line ..make it and enjoy..
thank u
Hi aman khalsa and all.
Thank you aman khalsa for final check B500 easy drive and i corrected for PCB.
Regards.
Old 28th December 2010, 02:42 AM   #1134
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Default tlo72 is not working....
Originally Posted by andrewlebon View Post
hi
greetings STEP DRIVER PROBLEM SOLVED NOW WORKING
THANKINGYOU
andrew lebon
hello sir my tlo 72 step drive is not working pls helo me out...
thank u,,
Old 31st December 2010, 02:16 PM   #1135
happy new year my frnd,s..
thank u...
Old 3rd January 2011, 02:55 AM   #1136
Mamak is offline Mamak  Malaysia
hai apex.i build your b500 amp.using 2 pair power output.when i supply +-50vdc amp cannot work but when using example +45 and -50.it will work.so it work when negative power supply more than positive.and when at 9 o clock still ok.but when 10 to 11 it will unstable.what my problem apex?
i follow your pcb 100% same.
Old 3rd January 2011, 02:58 AM   #1137
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 500W PA amplifier with Limiter
Post some picture showing wiring and close up picture so we can help you
since Apex is not online
Old 3rd January 2011, 03:07 AM   #1138
ok i will post picture another day because i chatting at cyber cafe now.when i use 2 pair power output it should change resistor value for adjust bias?or u think my ground connection problem?
Old 3rd January 2011, 03:11 AM   #1139
irvynejay's Avatar
maybe you have problem with your wiring,, i run B500 on trapo 55vac -/+75 work fine no problem
Old 4th January 2011, 12:41 PM   #1140
asia is offline asia  Philippines
Talking tlo step
thank u,,
hello friend,
maybe it's time to abandon TLO step,
try to manage to get ir2117,
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
