500W PA amplifier with Limiter
Old 24th December 2010, 04:01 PM   #1101
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
marry Christmas to all my DIR,s....
Old 24th December 2010, 04:03 PM   #1102
marry Christmas to all DIY,s....
Old 25th December 2010, 01:57 AM   #1103
engel dela pena is offline engel dela pena  Philippines
Originally Posted by andrewlebon View Post
hi apex audio
greetings want to ask you that can you please tell me if i am
wrong
1 pin 7 of ic TLO72 should go to base of transitor BF422 but 5 no pin is going to base
2 from 5 no pin 10K resitor should be ground
3 1 no pin of ic TLO 72 should go to base of transistor BF423 but 3 no pin is going to base
4 3 no pin should be ground via 10 K RESITOR
PLEASE TELL ME IF I AM CORRECT FOLLOWING SCHEMATIC
hopimg you can help me
thanking you
andrew lebon
hello mate,
which tlo step lay out are you using?
the corrected step lay out is in post923 and 928
Old 25th December 2010, 02:05 AM   #1104
apex,
in the picture you post the i.c. mounted not as the last corrected lau out,.so the step this picture is not yet tested?
Old 25th December 2010, 02:51 AM   #1105
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi engel dela pena
greetings check schematic against pcb component layout
after correcting mistakes on negative side negative out voltage is correct
will do positive side now and reply
thanking you
andrew lebon
MERRY CHRISTMAS TO ALL FOLKS ON DIY
Old 25th December 2010, 05:26 AM   #1106
wattaniya is offline wattaniya
my question is is it b500 need step driver? without step driver any effect?
which speaker protection is suitable for b500?
pls post the b500 correct pcb layout in pdf and speaker protection.
thank u for diy members.
Old 25th December 2010, 05:51 AM   #1107
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 500W PA amplifier with Limiter
B500 can run without step driver ,,step driver is just an upgrade so b500 become h class,,about protect circuit its on the thread and i use it for my b500 and h900 works great
Old 25th December 2010, 06:06 AM   #1108
There are lots of protect circuit in this forum . so which one u use? if u can post the pcb layout it is very usefull.
thank u for your reply.
Old 25th December 2010, 06:16 AM   #1109
irvynejay's Avatar
Default protect circuit APEX
APEX protection circuit can be use in any amps
File Type: jpg APEX H900 Protect Component layout.jpg (664.6 KB, 1389 views)
Old 25th December 2010, 06:22 AM   #1110
thank u for the spaeker protection pcb . but i read in this thread this is for h900 not suitable for b500. is it ok for b500?
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
