500W PA amplifier with Limiter
Old 8th December 2010, 10:11 PM   #1031
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by aman khalsa View Post
hello apex sir
pls tell me one thing if in case L.S of my b500 is short circuit what will happen .
is protection work?
With peak current over 8A per output circuit around 2N5401 give AC signal on amp PRO pin, and protect circuit disconnect speaker. Protect will connect speaker after turn amp off and turn on again (power on reset). If you not sure that usen outputs will not break with 8A current don't try to short circuit amp out.
Old 9th December 2010, 03:36 AM   #1032
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi aman
greetings any more faults on pcb
thanking you
andrewlebon
Old 9th December 2010, 12:06 PM   #1033
triast is offline triast  Indonesia
Originally Posted by apexaudio View Post
APEX B250 after two years in professional use.
Dear Sir apexaudio,
Would you share the pcb, schematic and BOM of B250?
Thx
Old 9th December 2010, 02:04 PM   #1034
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
no sir only one mistake ..
Old 9th December 2010, 02:49 PM   #1035
hi aman
greetings tested amp with 4 15 inch speakers 2 ohm load 10 output pairs
supply 70 0 70 dc performed more than i expected tomorrow will test with apex
audio modification triple ef stage and post pictures of set up
THANK YOU APEX AUDIO FOR YOUR CIRCUITS AND HELP have made 4 h class
h900s
1 is it normal when i start amp in series with 100 watt bulb it glows full then i
dissconnect speaker and recconect speaker bulb comes to normal is it ok
thanking you
andrew lebon
Old 9th December 2010, 02:57 PM   #1036
The bulb is used to prevent damage when your equipment is wired up wrongly (incorrectly).
Once you have tested the amplifier thoroughly, you must remove the bulb limiter and set up the amplifier to it's quiescent settings. Only after all that is completed should you attach the speakers.
regards Andrew T.
Old 9th December 2010, 04:16 PM   #1037
apexaudio's Avatar
Originally Posted by triast View Post
Dear Sir apexaudio,
Thx
Use pcb from B500 for B250 or I can suggest you to build HV350
MOSFET Amplifier IRFP240/IRFP9240
Old 9th December 2010, 04:21 PM   #1038
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi aman
h900s
thanking you
andrew lebon
Speakers are not connected when you start amp if you use speaker protect. It's normal when you start amp series bulb will glows at the moment (caps charge).
Old 9th December 2010, 06:50 PM   #1039
rhodrich is offline rhodrich  Philippines
hi aman
h900s
thanking you
andrew lebon
@ ANDREW
DID YOU USED THE AMAN KHALSA B500 DRIVE UNIT IS THERE ANY PROBLEM WITH THE BOARD? HAVE YOU TRY USING IT PLS ADVICE IM READY TO USED THE BOARD.
THANKS.
Old 10th December 2010, 12:55 AM   #1040
dekes1 is offline dekes1  United States
New guy here:
I don't have the ability to make my own PCBs. Does anyone have the Gerber and drill diagrams for the B500 (or the B500 with 6 output pairs version) that I could take to a shop that makes boards?
Thank you,
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3622 13th February 2018 09:56 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
