Old 3rd December 2010, 04:57 PM   #1001
sekhar is offline sekhar  India
rhodrich
u cant run b500 in bridge mode @ 4E . if need 2 drive b500 at bridgemode lower the voltage rail and run @ 8E....
regards
sekhar
Old 3rd December 2010, 11:39 PM   #1002
Originally Posted by apexaudio View Post
B500 based on schematics of H900, but in AB class.
Power supply +/-90Vmax.
apex said +/-90v dc
Old 3rd December 2010, 11:42 PM   #1003
and supply drops +/-10v underload
Old 3rd December 2010, 11:46 PM   #1004
how many reservoir caps can i use?
i see many builder using 4 pairs of caps or more,
how is that? the more the merrier,
Old 4th December 2010, 12:32 PM   #1005
Mamak is offline Mamak  Malaysia
Originally Posted by wg_ski View Post
If you use a light bulb limiter, you don't need to step it down first or use any DC protect. The light bulb is actually better than a variac. A lot of amplifiers will work perfectly at lower voltage and get unstable at full voltage. With a variac turned down it may behave, and then go bang very suddenly as it is brought up. The light bulb will let the amp get to 90% of normal voltage when it's idling, and bring it down automatically if it goes unstable.
sorry i dont understand.why use bulb?
amplifier just use example -+70v.how the connection of bulb with this amp?
Old 4th December 2010, 12:42 PM   #1006
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
A series light bulb, like this:
Light Bulb Current Limiter
Max.
All the best, Max.
Old 5th December 2010, 10:54 PM   #1007
apexaudio's Avatar
Originally Posted by rhodrich View Post
@ apex
Sir if b500 will be bridged at 77+- vdc because. i have trafo 55 0 55 2000va and loaded with 4 ohms. i think i will end up burning my amp. i will have peak to peak voltage of 154 then try loses or voltage sag to 134vdc p-p. so the amp power would be 4489 watts at 4 ohms. if the power is continues the current 33.5A. if it is possible to do this way how many trannies needed? maybe need to used mjl4281 bec. have higher voltage rating than 2sc500.
pls. comment sir apex about this. thanks alot
You need add predrivers (post #967) and use 7 pairs of outputs for 4 ohms load in bridge mode.
Old 5th December 2010, 11:59 PM   #1008
[QUOTE=apexaudio;2388456]You need add predrivers (post #967) and use 7 pairs of outputs for 4 ohms load in bridge mode.
Regards[/QU
thanks alot sir.
Old 6th December 2010, 12:11 PM   #1009
it prevents you blowing up your amplifier if you have made a mistake wiring it up.
Old 7th December 2010, 12:41 AM   #1010
1,2 - two pairs 2SA/2SC with +/-56V you will get about 120W/8R (resonable THD)
apex.b500 need step driver or not?or step driver only for h900?i still collect enough information to build this amp.i want to drive car subwoofer speaker.
900W H-class PA Amp with Limiter apexaudio Solid State 2540 17th May 2013 06:37 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2013 diyAudio
