Hi, I wonder, is this a cascode driver stage ?
#2 |
No, it is a darlington driver stage.
#3 |
Moschfet was faster
#4 |
A little more than a darlington, it s a triple emitter follower.
Since there s no resistors on the emitter s of the transistors that are in the middle of the arrangement, the crossconduction range around the 0V crossing point will be somewhat wider.. Also, the lack of this resistors make it imposible to discharge the stored charges if even the transistor is driven to saturation, wich is not a poblem in this case as they are fed from the same supply voltage that their drivers, so they can t be driven to saturation. |
#5 |
Apparently this one use one reversed output N device on output P side
Which is different ? I wonder why there are no cascoded driver stage to find anywhere ? |
#6 |
Q5/7 and Q6/8 are feedback pairs.
All the trouble I've ever been in started out as fun......
#7 | |
Samuel |
#8 |
#9 |
#10 |
Banned
A cascode generally has the emitter of one device connected to the collector of a second, whereas in your first circuit the emitter connects into the base of the second.
Of course you can build the circuit with FETs, where it's source->drain, or valves, where it's cathode->anode. Just because you see the devices stacked in this way, it does not necessarily mean that the circuit is a cascode. As with most circuits, it's worth googling them and looking at wikipedia... cascodes are characterised by a high input impedance and high frequency response, the latter due to the minimisation of the effect of Miller capacitance. w |
| Amp that can drive low impedance ribbon? | bjorn.lindberg | Solid State | 34 | 17th October 2005 03:37 PM |
| Kicker DX700 classD; how can it drive a 1ohm load? | SHOdown | Class D | 42 | 8th February 2005 12:22 AM |
| direct drive ribbon amp | hancock | Pass Labs | 38 | 19th December 2004 01:58 AM |
| Small amp to drive Ribbon Tweeters | EC8010 | Tubes / Valves | 59 | 6th May 2003 11:44 PM |
| Page generated in 0.09319 seconds (79.24% PHP - 20.76% MySQL) with 11 queries |
