Happen to have the power supply PCBs as well?Here you can order a pcb Apex-14:
https://www.pcbway.com/project/shareproject/Apex_AX_14_2.html
And here you can order Apex-17. Also a good amplifier.
https://www.pcbway.com/project/shareproject/Apex_AX17_amplifier.html
There are simple with a diode bridge and diodes.
https://www.pcbway.com/project/shareproject/COMPACT_CRC_PSU_0dea58f5.html
https://www.pcbway.com/project/shareproject/COMPACT_CRC_PSU_6669f266.html
Thank you so much, i found it...Looks pretty similar to Evens Audio Speaker Protector PT-230A .
No tested yet
Have you already assembled it?Thank you so much, i found it...
Works ?
I have compared your PCB VS my design that I copied a long time ago and that I have now returned to and I notice certain differences between tracks....
Greetings
Sir Can you Share Pdf For home eatchingAX 14 with two pars.
https://www.diyaudio.com/community/threads/100w-ultimate-fidelity-amplifier.164093/post-5225852Sir Can you Share Pdf For home eatching
Post#9952
- 100W Ultimate Fidelity Amplifier
