100W Ultimate Fidelity Amplifier
Old 15th June 2017, 04:00 PM   #9671
aliskamjad is offline aliskamjad  India
Default Apex AX-14
Originally Posted by aliskamjad View Post
Good Afternoon Mr.Mile,
Can I use C3856/A1492 instead of C5200/A1943, if yes then do i need to change anything using rail voltage +/-56V, and which will be better c5200 or c3856 in terms of sound qualtiy and stability.
Thanks Mr. Mile for this wonderfull Amplifier, bass & treble is excellent. Thank you very much once again. Wow.....
Old 15th June 2017, 07:06 PM   #9672
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Can you post some pictures of your work.
Old 16th June 2017, 04:29 PM   #9673
Default Apex AX-14
Good Evening Mr. Mile,
This i made as a test amp, now I'll build a stereo version in a single board. Need some more help from you regarding protection circuit.
Old 18th June 2017, 10:00 AM   #9674
riohardi0205 is offline riohardi0205
FA9 class A
hi mr. mile, newbie here. i almost finish populating the pcb board (FA9). if i change bd139/140 to 2sc5171/2sa1930, is there any significant difference? say, high or mid tone.
regards,
rioClick the image to open in full size.
Old 18th June 2017, 12:31 PM   #9675
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
I have sent pcb files of AlexMM's version 1.4 of APEX A40 to be done by a friend of mine (the same one will make me APEX SR300 boards). as soon I do any progress I will post results.
Chop your own wood and it will warm you twice
Old 18th June 2017, 06:03 PM   #9676
44250's Avatar
Default AX30
i have done some prepairing to draw a pcb for APEX AX30:
Old 19th June 2017, 07:44 AM   #9677
thimios is offline thimios  Greece
I haven't check for possible wrong connections but i must say that is a clever clear schematic diagram!
Old 19th June 2017, 11:48 AM   #9678
44250's Avatar
true,but it is not really "peace of cake" to draw a pcb for it,there is a lot of transistors that need to be together on a same heatsink and also to avoid too much jumpers. really not a usuall schematics,at least for output stage.
Old 23rd June 2017, 08:44 AM   #9679
44250's Avatar
two pcb for APEX A40 made by files from AlexMM ver1.4,hopefully soon assembled:
Old 25th June 2017, 03:51 PM   #9680
still4given is offline still4given  United States
still4given's Avatar
That's some beautiful etching there!
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
