100W Ultimate Fidelity Amplifier
Never used that transistor.
I’m getting confused on what you need and for what amp? Show a diagram please.
There are MPSA92 and an alternate KSPA92 (with higher Hfe but I can’t find these available)
As well there are KSA992, which replaced 2SA992
Note these are different parts and not interchangeable generally.
And what you linked is none of these I listed above.
Sorry. For T6 and T6' on Prasi's FH9 XRK mod. Thr silkscreen just says SA92.
Mouser are out of stock of MPSA92 and so I didn't know if the above linked KSA928 was a substitute.
I have attached an alternate schematics FH11 - difference is number of outputs. It shows shows T6, as a MPSA92.
Someone will correct me - but I don't think the KSA992 has enough current capability for that location.
But there are substitutes - You could use 2N5551 for the T1/T2 c1845, you can substitute the MPSA92 for a MJE350 (however different package and pinout)
If you have issues finding some parts - send me a PM, I have most of these in my stash.
