100W Ultimate Fidelity Amplifier
Old 23rd January 2011, 03:29 PM   #611
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by viki_v2 View Post
Can both be used
Yes both can be used, and some other PSUs.
Old 24th January 2011, 05:38 AM   #612
JLesterP is offline JLesterP  Philippines
Originally Posted by apexaudio View Post
Picture not clear, but your soldering don't look good.
Ok i'll just try again... will it sound good even if I use ceramic and mylar caps?
Old 24th January 2011, 05:47 AM   #613
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Does this psu provide regulated supply. Also give pcb diag for etching
Old 24th January 2011, 07:04 AM   #614
Ok i'll just try to make a new one...
Does it sound better than a gainclone even if i use ceramic and mylar caps?
Old 24th January 2011, 08:53 AM   #615
apexaudio's Avatar
Better than any gainclone, and better than most discrete amps
Old 24th January 2011, 08:55 AM   #616
apexaudio's Avatar
No, this PSU is with soft start for main transformer and separate protections for each channel.
Old 24th January 2011, 09:05 AM   #617
viki_v2's Avatar
CAn hv350 be used with sanken 2sc2922-2sa1216 or mjl21193/94, if yes any changes
I want the amp to sound good , but i need more power, which pcb should i use , ax-14 uses just single pair, i dont want to compromise on sound quality.
I completed my tower speakers, installed crossevers, connected to amp,
Result-Bass is good but seems a bit boomy, Mids and highs are not clear dont sound in ratio to lows.
Could this be due to amp . I got this kit and assembled it. Pls check
MX100 Stereo 200W+200W amplifier kit - eBay (item 200548641672 end time Dec-05-10 20:00:01 PST)
Old 24th January 2011, 09:17 AM   #618
viki_v2's Avatar
i need 250 watt rms at 8ohms, but hi-fi sound
Old 24th January 2011, 09:26 AM   #619
apexaudio's Avatar
HV350 is MOSFET amplifier, BJTs can't be used, I suggest B500 or SR200 from Studio Reference Amplifier post #35, but I not made DIY version pcb jet.
Old 24th January 2011, 11:40 AM   #620
viki_v2's Avatar
i am bothering too much, But cant help as i need to make a amp for my floorstanders.
Will hv350 have same sound quality as Ax-14. And what will be the output at 8 ohms
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
