100W Ultimate Fidelity Amplifier
Old 22nd January 2011, 08:56 PM   #601
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
AX14 wireing with speaker terminal
Old 23rd January 2011, 05:23 AM   #602
JLesterP is offline JLesterP  Philippines
Hi i'm a newbie in diyaudio, how and where to measure the quiescent current when adjusting the bias pot?
thanks
Old 23rd January 2011, 07:12 AM   #603
coolet is offline coolet
coolet's Avatar
For BIAS adjust put 10R resistors instead fuses and set 500mV on them.
Old 23rd January 2011, 09:34 AM   #604
My amp doesn't work... 0V across fuses/10ohm resistors, 36V between + & - fuse clips, no smoke, no transistor heatups when adjusting bias pot, variable dc offset when no output load, but the speaker pops when connecting to output terminal... what could be the problem? does the driver transistors sensistive to heat? I think I overheated them when I soldered it to the pcb...
Thanks!
Old 23rd January 2011, 10:52 AM   #605
apexaudio's Avatar
Thanks!
Can you post pictures, do you connect input GND to PSU GND?
Old 23rd January 2011, 12:24 PM   #606
yup, i connected the input and output gnd to psu to gnd ground
Old 23rd January 2011, 01:01 PM   #607
viki_v2 is offline viki_v2  India
viki_v2's Avatar
How to connect this pcb to ax-14 amp, does this have voltage regulation
File Type: jpg APEX%20F100PSU%20PCB pcb size 90x130.jpg (762.9 KB, 1729 views)
Old 23rd January 2011, 01:30 PM   #608
apexaudio's Avatar
yup, i connected the input and output gnd to psu to gnd ground[/QUOTE]
Picture not clear, but your soldering don't look good.
Old 23rd January 2011, 01:31 PM   #609
apexaudio's Avatar
First is PSU with protect, second is regulated PSU.
Old 23rd January 2011, 01:59 PM   #610
viki_v2's Avatar
Can both be used
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
