100W Ultimate Fidelity Amplifier
Old 11th January 2011, 12:13 PM   #521
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 100W Ultimate Fidelity Amplifier
Default A question about complementary pair matching
Originally Posted by apexaudio View Post
2SA1306/2SC3298
I have ordered the complementary pair 2SA1837/2SC4793, but I have received 2SC2336 in place of the latter. I see they have some differences in figures, like higher capacitance in C2336, and also lower gain.
The question is: do you think there would be any problem trying 2SA1837 with 2SC2336 for AX14?
By the other side, I have already built a single-pair output amplifier, and my needs are for a double-pair (small PA applications), since mine worked fine in the living room, but had a big lack in power when tested inside a medium size room (restaurant).
So, I also vote for a more powerful AX-14 version, even with Mosfet output (I will try NX-14, and would like to have it with two output pairs).
Thanks for your hard work.
Max.
Edit: Maybe the problem with my amplifier is the low rail voltages of 35+35VDC. Maybe a higher voltage driven amplifier would do the job. But I think a double-pair output would handle different kind of loads much better, even a lower impedance speaker parallel connection.
Max.
Old 11th January 2011, 01:22 PM   #522
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Max.
2SC2336/2SA1006 can be used as drivers for AX-14.
With +/-35V rail voltage output power is 50W/8R, use +/-50V rail voltage and U will get 100W/8R. With 2 pair of outputs and +/-56V rail voltage output power will be 175W/4R RMS.
Old 12th January 2011, 05:04 AM   #523
coolet is offline coolet
coolet's Avatar
sorry for repeated question... i just finished ax14 i just want clarification before i put power on it . the left picture is the original schematic while the right one is for the actual pcb schematic... which one is correct? d4 and d5
Old 12th January 2011, 05:34 AM   #524
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
Hello Mile,
If I need 20 clean watts, which has a more hifi and accurate sound - the Studio Reference SR50 or this 100W Ultimate fidelity amp ? I will be building either of the amps and etching my own board. (first time)
Old 12th January 2011, 05:47 AM   #525
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi coolet
greetings first schematic ic correct DIODES D4 D5 FROM POSITIVE
SUPPLY TO SPEAKER OUT FROM NEGATIVE SUPPLY TO SPEAKER OUT TO
THANKING YOU
ANDREW LEBON
Old 12th January 2011, 08:51 AM   #526
apexaudio's Avatar
I repeat answer: both connections are correct. If you want add more outputs use first circuit, pcb for AX-14 with single pair of outputs use second circuit. Use 10R instead fuses for first powered and set bias to get 500mV on 10R.
Old 12th January 2011, 09:03 AM   #527
apexaudio's Avatar
Originally Posted by chlorofille View Post
Hello Mile,
If you build either of the amps you can compare them. AX-14 sound more neutral on mid and high. I like bass from SR50, but speakers is more important for sound quality.
Old 12th January 2011, 05:07 PM   #528
Mile, I will try out the AX-14 then. Thanks again for sharing your amp designs.
Old 12th January 2011, 06:52 PM   #529
apexaudio's Avatar
You can try any amp, but you must try AX-14, that is my suggestion to all diyers.
Old 13th January 2011, 05:11 AM   #530
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Default trannies for ax-14
Hi apex
For ax-14, can i use 2sc2922, 2sa1216 or 2sk1530.2sj1201 pair.
pleae reply as i am eagerly waiting to etch the boards.
Also do i need to change anything. Any changes for power supply.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
