100W Ultimate Fidelity Amplifier
Old 11th December 2010, 04:11 PM   #431
emmi is offline emmi  India
does this amp work for continues program that is for listening songs ultimately
Old 11th December 2010, 07:23 PM   #432
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
I don't understand this question.
Old 12th December 2010, 03:55 AM   #433
does this amp work for PA applications?
Old 12th December 2010, 11:33 AM   #434
apexaudio's Avatar
This is amp for 'Home Audio', but can be use for PA applications with short circuit protection from 'DC Servo Mosfet Amp' PSU.
Old 13th December 2010, 12:52 PM   #435
what will be the maximum output power if the rail voltage is +/-75 and how much load can i put on it
Old 13th December 2010, 01:14 PM   #436
R.I.P.
expect a +-75Vdc supply to sag between 5V and 10V depending on how you build the PSU.
Expect the amplifier to drop/lose another 5V before it feeds the output.
Combining these two losses, expect ~60Vpk at the output.
P = Vpk^2 / Rload / 2
225W into 8r0, 450W into 4r0.
Work all the other impedances out from this model.
If you want 225W into 8r0 from it, then expect to provide 900W of mosFET output stage or 1200W of BJT output stage.
If you want/need to drive 4ohms speaker then double the wattage of the output stage.
regards Andrew T.
Old 13th December 2010, 02:36 PM   #437
why do we need 900watt of mosfet output stage for 225watt into 8 ohms
i didn't understand your answer
Old 13th December 2010, 04:24 PM   #438
R.I.P.
I think you understand my statement.
I also think you don't like my statement.
regards Andrew T.
Old 13th December 2010, 05:24 PM   #439
svsommer is offline svsommer  Denmark
Hello
how do I print the pcb layout correctly formatted
sincerely
svsommer
Old 14th December 2010, 01:14 PM   #440
why do you think so
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
