100W Ultimate Fidelity Amplifier
Old 7th December 2010, 11:07 AM   #421
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 100W Ultimate Fidelity Amplifier
Where are the heatsinks???
Max.
Old 7th December 2010, 11:11 AM   #422
Mamak is offline Mamak  Malaysia
i still not install.i only want try first.if it work.i will cut the heatsink
Old 7th December 2010, 11:17 AM   #423
Amp needs heatsink even for testing purposes!
Use something for a while, improvise.
No heatsink will lead to pain...
Max.
Old 7th December 2010, 12:39 PM   #424
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Mamak View Post
plez check apex.now i disconnect diode at power output.sorry picture not good quality
I need pictures with PSU and wireing, I can't see enough for help you, give some informations about rail voltages, do you use 10R resistors instead fuses for bias setup?
Old 8th December 2010, 02:48 AM   #425
no sir.should i install 100 ohm res?
Old 8th December 2010, 08:18 AM   #426
apexaudio's Avatar
Yes, and don't connect speakers if there is DC offset on the amp output...
Old 10th December 2010, 11:10 AM   #427
Blue PCB
apex.if i add 1 pair 2sc5200,what voltage supply rail?
Old 11th December 2010, 01:51 AM   #428
apexaudio's Avatar
If you add one or more pairs of outputs no need to change rail voltage, exsept you want more power...
Old 11th December 2010, 04:49 AM   #429
yes.i want add 1 more pair output.and want more power.what voltage rail should i give?and bias adjust still 4.7v?
Old 11th December 2010, 10:26 AM   #430
apexaudio's Avatar
For bias adjust use 10R instead fuses and set 1V on them for single pair or 2V for two pairs. I suggest rail voltage +/-45V for single pair or +/-55V for two pairs (+/-65V 3 pairs, +/-75V 4 pairs, +/-85V 5 pairs and +/-95V 6 pairs or more).
DC offset is about +/-10mV.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
