100W Ultimate Fidelity Amplifier
My FH-9 in An old ATX psu case with external power. Good sounding amp, better than gainclone which was before in that case.
regards
zoky2
FH9 HV Edition
I just built another FH9 with components for 53v rails. 2N5551 instead of BC546 and 2SC3503 instead of BD140 and 2SA1381 instead of BD139. All power rail electrolytics are 63v, feedback cap is 1000uF 35v. All bypass 100nF bypass caps are 400v film. Will test tomorrow with fresh eyes. The only odd thing was that the 2N5551 had reversed pins so now flipped around. The BD's and SA/SC's are same pins.
You can keep BC546 for 53v rails.
