100W Ultimate Fidelity Amplifier
Old 24th August 2010, 06:36 PM   #301
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default Nx14v2 pcb
This pcb for NX14V2 is fixed on heatsink, and you soldering outputs on coper side of pcb. Montage outputs is much easy this way.
Old 24th August 2010, 08:19 PM   #302
apexaudio's Avatar
With pcb NX14V2 BC560C with reverted pins can be used instead 2N5401, just rotate case for 180deg.
Old 25th August 2010, 01:35 AM   #303
electra_ina is offline electra_ina  Indonesia
electra_ina's Avatar
Hi..Apex..for Nx14v2..can I used Tr 2SA1668/2SC4382 instead SA1837/SC4793 for driver??
Pozdrav..
Old 25th August 2010, 08:36 AM   #304
apexaudio's Avatar
Pozdrav..
2SA1668/2SC4382 can be used for drivers in any version of 'Ulti-Fi' amp.
Pozdrav
Old 25th August 2010, 09:08 AM   #305
Thanks Apex...I will built it.
Old 25th August 2010, 01:57 PM   #306
apexaudio's Avatar
Use 10R in parallel with C13(100nF) for test or GND wirwing circuit as I suggest for all my amps (GND from PSU to input terminal),
Old 25th August 2010, 02:52 PM   #307
RSK is offline RSK  Malaysia
Miles,
I have many IRFP452 (TO-3 metalcan) by samsung. Can this be used here?
They are from old PSU.
Thanks.
Old 25th August 2010, 03:44 PM   #308
apexaudio's Avatar
Originally Posted by RSK View Post
Miles,
Thanks.
You probably have IRF452 in TO-3 case, IRFP452 is in TO-247 case like IRFP250. Any of this MOSFETs can be used for NX14 amp.
Old 25th August 2010, 04:16 PM   #309
You are right Miles. IRF452 is the one. So it can be used!
Thanks.
Old 25th August 2010, 04:26 PM   #310
apexaudio's Avatar
Thanks.
There is IRF450 and it can be used also. MOSFETs are from IR not from SAMSUNG.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
