100W Ultimate Fidelity Amplifier
Old 15th November 2013, 09:48 AM   #2851
Maroof is offline Maroof  Pakistan
Hi apex,
I have made nx14 using IRFP460 . sound is very good and clean. Thanks for providing such nice a circuit . Do u have any circuit which only uses N channel FET and can provide 300w to 500w at 4ohm load?
Old 15th November 2013, 10:14 AM   #2852
R.I.P.
Quasi did a few projects that meet that spec.
regards Andrew T.
Old 15th November 2013, 12:49 PM   #2853
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Maroof View Post
Hi apex,
Nice, can you post pictures?
Old 15th November 2013, 03:07 PM   #2854
Sorry it was only a test setup with unregulated power supply so I disassemble the circuit . But i will definitely post pictures when i complete my amplifier.
Apex, can i parallel 5 pairs of FETs to get 500w on 4ohm load using NX14 circuit ? then what should be DC supply voltage ?
Old 16th November 2013, 10:51 AM   #2855
Vostro is offline Vostro  South Africa
Vostro's Avatar
This simple shunt regulator can be use with AX amplifiers for preamp supply. Amp rail voltage can be use for regulator input (without 1N4007 diodes and 4700uF caps).
Mr Mile
Is it best to use 2x24Vac transformer or is a 2x18Vac transformer OK regarding this preamp regulator circuit
Old 16th November 2013, 11:46 AM   #2856
apexaudio's Avatar
Originally Posted by Vostro View Post
Mr Mile
Use 2x18v AC
Old 16th November 2013, 12:24 PM   #2857
Vostro's Avatar
Use 2x18v AC
Old 16th November 2013, 04:14 PM   #2858
shravanth is offline shravanth  India
apex which output will be good and natural AX-14 or NX-14
Old 22nd November 2013, 06:10 PM   #2859
kandimba is offline kandimba  Portugal
Default AX20
Hi mr Mile ! I took so long but here I am like a snail walking ... with my first AX20 channel and NE555 protection, clip led, signal led and power led, in same pcb. Everything is working perfect, power supply +55VDC – 55VDC, DC ofset – 2,5mv. I changed C9 and C10 to 33pF to avoid visible oscilations, I replaced R16 to 1K5 to get enougf bias, 15mv across R33/5W. Is it normal to get 3,54V across colector/emiter of BD139? This amplifier sounds veeeeeeery good, sine wave is perfect, but when I use dummy 8R square wave, you can see the diference betwen with 1uF in paralel or without, is this normal ? In scope, you see 1KHz and 5V per div. I dont have over shooting obssesion anyway ... Output sine Wave 1KHz without clip: 8R 32VAC, 128W, 4R 30VAC, 225W. About supply for NE555 (12VAC) protection, what should I do ? Should I put a smal transformer for it, or get 12VAC from a special winding to the main transformer that I have to order. Thanks a lot Mile !!!!!!!!
Pozdrav
Old 22nd November 2013, 11:02 PM   #2860
apexaudio's Avatar
Pozdrav
Nice work... 12VAC supply for NE555 you can get from special winding to the main transformer.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
