100W Ultimate Fidelity Amplifier - Page 276 - diyAudio
Old 27th September 2013, 02:16 AM   #2751
albertli's Avatar
Originally Posted by jaagut View Post
Congrats! DC at your outputs are acceptable, I even have 50mV on mine and it's fine.
So, what did you do to solve your bias problem?
I parallel a 50k trimmer to the 4k7.
Old 27th September 2013, 03:26 AM   #2752
jaagut is offline jaagut  Philippines
I see, so so you opted to adjust the emitter-base resistor, instead of the base-collector. trimmer should be set at maximum resistance value initially, and lower the value to increase the bias current. but be careful not to adjust the trimmer to zero.
setting trimmer in series with 1k or 1k5 resistor is much safer in practice but not so easy to do than setting it in parallel.
Old 27th September 2013, 01:09 PM   #2753
albertli's Avatar
I thought the other way. It's safer to parallel with a fixed resistor in case the trimmer open.
Old 29th September 2013, 10:38 AM   #2754
Idefixes's Avatar
Send a message via ICQ to Idefixes
Yesterday i etch a couple of board based on Borys layout...I am waiting some parts to populate them.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 29th September 2013, 03:18 PM   #2755
albertli's Avatar
Default In quest of bass
Hi all,
I have been listening to my AX11 mk2 for two days with no less then 10 hours. As said by the other members and all claimed that this design produces really good bass, but I don't have this feeling with my build. This is to compare all amps that I have of which include 6c33c otl, 6c33c se, Moskido and 807pp. I don't know if I have done anything wrong. I build this with the pcb posted at #2201 with BC546b instead of 2N5551, all other parts are same on that pcb. Power supply is Mur860 to 10,000uf to 33ohm wrapped with 40 turn 1mm wire as coil to another 10,000uf so to make the total of 20,000uf on each of + and - 35v rail.
Albert
Old 29th September 2013, 04:55 PM   #2756
cjkpkg is offline cjkpkg  United States
Hi all,
Albert
For PSU is it 33 or 0.33? Hopefully 0.33...
I am using 3x0.47 in parallel between the caps. Mine are also 10,000 uF x2 per rail.
What are your emitter resistors? I am using Fukushima mpc
What type of cap are you using for the 10uF input cap? I am using nichicon UFG or UKW I forget....both are audio grade.
Old 29th September 2013, 05:34 PM   #2757
albertli's Avatar
Hey Carl,
They are 33 ohm,but only 0.46 ohm after parallel with the 40 round coil. I copied from the smymsyn thread. If this is the devil I can replace them with wire.
The 10uf input caps are blackgate monsite.
Albert
Old 29th September 2013, 05:53 PM   #2758
Hey Carl,
Albert
Ok good...I would crank the bias up as high as you feel comfortable and let it break in. Which outputs did you use?
Old 29th September 2013, 06:26 PM   #2759
albertli's Avatar
They are running at 60mv since day one n I only found 33c at heatsink after 4 hours. I will crank them up to 100mv after I regroup my psu by taking out the 33 ohm / coil with a wire. Or do you think it better to put a big resistor there ?.
Do you mean the output transistors? TO-3 MJ15003/4. All my speakers are 8 ohms.
Old 2nd October 2013, 09:09 PM   #2760
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
AX-16 2 pairs...DC offset is 2.4mV...
Sounds very good!!!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2017 diyAudio
