100W Ultimate Fidelity Amplifier
Old 24th September 2013, 02:10 AM   #2741
albertli is offline albertli  Canada
albertli's Avatar
Originally Posted by cjkpkg View Post
Double check there is no continuity from the case of the to-3 and the chassis. I had a devil of a time when screwing them to the L bracket.
I had to sand the surfaces around the drill holes a lot to keep the outputs isolated.
I am using silpads.
I will double check that. What I did was fitting a heat shrink tube to the screws, n that had been checked for couple times before I turn the power on, but no harm to check one more time.
Old 24th September 2013, 11:33 AM   #2742
maouna is offline maouna  Greece
hi. i am looking for the schematic and pcb files of AX14P with DC and overload protect on pcb.can anyone help me?
Old 24th September 2013, 11:39 AM   #2743
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Post# 1547 & 1565
Old 24th September 2013, 02:36 PM   #2744
Originally Posted by wiljj78 View Post
thanks a lot!!
Old 25th September 2013, 11:41 AM   #2745
kandimba is offline kandimba  Portugal
You can see #2436 also, for AX14P
Old 25th September 2013, 01:08 PM   #2746
Abnormal dissonance is offline Abnormal dissonance  Russian Federation
Hi!
How I can change (reduce) gain this amp?
Old 25th September 2013, 01:57 PM   #2747
R.I.P.
If you change the gain, you also change the feedback.
That usually requires a change in the compensation.
regards Andrew T.
Old 26th September 2013, 07:33 AM   #2748
Thanks for reply.
Can somebody help - what nominals of compensation elements (R11 - C7, R8 - C6) must use for gain 32dB?
Old 26th September 2013, 01:39 PM   #2749
albertli's Avatar
Talking It's up running
Amp was running stable at 15mV for about an hour last night. It drifted a bit but can easily adjust them back to 15mV after 20 minutes. Temperature on my heatsink was only 28C. I thought I could run them a bit hotter so to test the sound is better or.....
There were -15mV and -9.5mV at output. Don't know if I have to make any correction to this issue.
Have to put up a protector, so I could taste the good sound.
Old 27th September 2013, 01:57 AM   #2750
jaagut is offline jaagut  Philippines
Congrats! DC at your outputs are acceptable, I even have 50mV on mine and it's fine.
So, what did you do to solve your bias problem?
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
