100W Ultimate Fidelity Amplifier
Old 30th July 2013, 10:07 AM   #2531
borys is offline borys  Ireland
borys's Avatar
Originally Posted by apexaudio View Post
Nice work, I use 2SK117 in my HD series amp with 3mA bias per j-fet and diamond differential VAS.
Would You know any j-fet siutable for 50V ?
I will try higher bias for j-fet too.
Old 30th July 2013, 10:22 AM   #2532
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
I suggest to cascode j-fets or use 24V zeners.
Old 30th July 2013, 10:51 AM   #2533
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Sound interesting....
Mr. Mile would that HD series preparation includes AX11 and AX-14?
Old 30th July 2013, 09:56 PM   #2534
borys's Avatar
wiljj78
Bellow You have packet with bit modyfiet board.
Just replace bc546 at the input with 2sk170 (do not go over +/-40V with fets).
Old 30th July 2013, 10:10 PM   #2535
wiljj78's Avatar
wiljj78
Many thanks borys.... and Yes i will try this with +/-38vdc max.
Old 31st July 2013, 02:41 PM   #2536
joeyt is offline joeyt  Philippines
Default ax-11 need help
i pulled out transistors except the bc546 and mpsa92. tested them and they are all good.put them back and measured their voltages.
2sc5200 2sa1943 bd139 bd140 2sa2383 2sc1013
vbc-13.49v vbc-0.7v vbc-8.95v vbc-395mv vbc-200mv vbc-8.69v
vbe-0.2v vbe-0.2v vbe-16mv vbe-15mv vbe-215mv vbe-42mv
vce-16.9v vec-11.9v vce-12.7v vce-655mv vce-190mv vce-8.79v
mpsa13 vce-0v and amp out is 13.5v
all ground have individual wire come from psu ground. can i know what was the trouble of this ax-11 pcb?
thank you
joeyt
Old 31st July 2013, 02:55 PM   #2537
2sc5200 -vbc13.49v/ vbe- 0.2v /vce-16.9v
2sa1843-vbc 0.7v/ vbe-0.20v /vce-11-9v
bd139 vbc-8.9v /vbe16mv /vce-12.7v
bd140 vbc-395mv /vbe-15mv /vce-655mv
2sa2383 vbc-200mv / vbe-215mv / vce-190mv
2sc1013 vbc-8.69v / vbe-42mv /vce-8.79v
this is a correction from my last posted.
thanks
joeyt
Old 31st July 2013, 03:42 PM   #2538
Your Vbe voltages are all too low. None of those transistors are turned on.
regards Andrew T.
Old 31st July 2013, 07:02 PM   #2539
apexaudio's Avatar
thanks
joeyt
What about voltages on BC546 and MPSA92?
Old 31st July 2013, 10:45 PM   #2540
bc546 collector connected to base of mpsa92
vbe-0.36v /vbc-27.8v /vce-25.9v
vbe-606mv /vbc-16.8v /vce-18v- after 10 mins.
bc546 base connected to 330pf
vbe-4.8v/ vbc-34.4v /vce-26,3v
vbe-8v /vbc26.5v /vce18.8v -after 10 mins.
bc546 base connected to - pin of in4148
vbe-4.81v /vbc-15.46/ vce-10.78v
mpsa92
vbe-565mv /vbc-30v /vce-30v - same v measurement after 10 mins.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
