100W Ultimate Fidelity Amplifier - Page 252 - diyAudio
Old 25th July 2013, 02:07 AM   #2511
jaagut is offline jaagut  Philippines
Originally Posted by ridelperez34 View Post
I already tried rotating 180 the mses. I also checked that the transistors match pcb layout.
I'll check it again. Thanks
if there is fault on the circuit, some transistors can be destroyed during testing without the evidence of physical burns. remove them from board and test it again with multimeter.
Old 25th July 2013, 11:08 PM   #2512
borys is offline borys  Ireland
borys's Avatar
I made some small changes to ax11 amp - as sansui au217 amplifier (preaty same amp) and have smmall question - can the input buffer be bypassed and input pair be substituted with 2sk170 tranies ?
I have made some simulations and amp is preatty quick and looks stable.
The square is 20kHz
THX
Old 26th July 2013, 12:27 AM   #2513
joeyt is offline joeyt  Philippines
ready for testing
Old 26th July 2013, 03:29 AM   #2514
Originally Posted by joeyt View Post
ready for testing
nice build and heatsink!
Old 26th July 2013, 04:49 AM   #2515
ang galing!
Old 26th July 2013, 08:45 AM   #2516
can i have the voltages measurement of ax-11? my ax 11 have a 5v in amp out without the output transistor.
Old 26th July 2013, 09:39 AM   #2517
usually this happens when signal ground is not connected to PSU ground.
normal reading of DC offset should be lower than +/-50 millivolts.
edit: output trans must be installed.
Old 26th July 2013, 11:54 AM   #2518
i insert a wrong transistor replacement for bd139, hope this is only the problem
joeyt,
Old 28th July 2013, 02:34 PM   #2519
Hi already replaced all the bcs and 5401 transistor but still have 7volts dc offset. Pls help
Old 28th July 2013, 06:03 PM   #2520
Send a message via Skype™ to overall feedback
Give us schematic with voltages on resistors
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2017 diyAudio
