100W Ultimate Fidelity Amplifier - Page 242 - diyAudio
Old 20th June 2013, 08:33 PM   #2411
Send a message via Skype™ to overall feedback
Yes it is Q8 fault. Maybe wrong orientation (pins), maybe base-emiter open circuit.
Old 20th June 2013, 11:02 PM   #2412
caglarm is offline caglarm  Turkey
I think shematic is wrong..marked point should be disconnected.
Old 20th June 2013, 11:45 PM   #2413
jaagut is offline jaagut  Philippines
Originally Posted by wiljj78 View Post
Bro... Consider also to double check pin orientation of MJE's 340/350 by meter, be sure you inserted correctly, this is one of the case if you have huge offset when inserted inverted pins one of your pre-drivers.
It happens to me in middle east MJE340 by ON semiconductor as per datasheet pins are ECB but in actual check by meter it’s BCE.
Good luck...
Thanks Bro, I did what you told and sure the MJE340 Motorola make has BCE pins!
Issue resolved when I rotate the transistor 180 degrees.
DC offset has gone from 59V to -16mV.
I tested loading input with music, and it works!
Old 20th June 2013, 11:56 PM   #2414
Originally Posted by AndrewT View Post
If Onsemi state it is ecb and your version is bce then whether it has Onsemi on it or not, it cannot be Their To126 transistor.
My other transistor in this setup was MJE350 from OnSemi. When I tested, pins are ECB.
Old 21st June 2013, 04:25 AM   #2415
thimios is online now thimios  Greece
Default AX11 under....test!
Yes shematic in this point is wrong but pcb is o.k.
By the way this is shematic for AX11.
Old 21st June 2013, 10:34 PM   #2416
Actually there is one more wrong dot - emitter of MPSA13 is not connected to GND.
I warned Apex on our local forum, so he gave corrected schematic.
Here it is:
Old 22nd June 2013, 12:44 PM   #2417
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
things started to get messy, and very confusing
I removed a few posts
please try to keep it clean for now, thanks
moderation
Old 23rd June 2013, 06:24 PM   #2418
Hello apex sir i need to add NFB for ax-14 or no need
Old 24th June 2013, 07:14 AM   #2419
joeyt is offline joeyt  Philippines
hello sir apex,
what is the possible substitute of bd 139, bc639 and bc640 for ax11, i cannot find this transistor here in our place.
Old 24th June 2013, 08:35 AM   #2420
apexaudio's Avatar
2SC2383, 2SA1013 instead BC639, BC640 and 2SB649, 2SD669 instead BD139, BD140.
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2017 diyAudio
