100W Ultimate Fidelity Amplifier
Old 1st May 2013, 12:48 PM   #2051
olafk is offline olafk  Germany
Now I changed all 330p to 100p. Slew rate is better as expected.
(10 + 20kHz). I hope, the probes are correct, but 20cm wire.
regards
Old 1st May 2013, 01:39 PM   #2052
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
regards
Thank you for this measurements, result is very good.
Old 1st May 2013, 02:28 PM   #2053
R.I.P.
This latest pic looks different from the previous input.
Have you swapped scope probes?
I ask again
Are your probes adjusted to show squarewaves correctly?
regards Andrew T.
Old 1st May 2013, 02:54 PM   #2054
No, I did not swapped the probes. But I changed the Cap at input from 330 to 100p.
It looks like a better slew rate but a bit more overshoot. But I have no particular experience.
regards Olaf
Old 1st May 2013, 02:56 PM   #2055
Have you seen the input without amplifier? Looks good.
If amp is connected, input has peaks?!
reegards Olaf
Old 2nd May 2013, 07:53 AM   #2056
Denmas is offline Denmas  Indonesia
I like the Apex AX11, and this is not foreign to me because it is similar to the scheme Sansui AU217
Greetings Denmas.
Old 2nd May 2013, 08:41 AM   #2057
apexaudio's Avatar
AX11 with TO3 outputs
Old 2nd May 2013, 10:15 AM   #2058
apexaudio's Avatar
Greetings Denmas.
Thanks for this info, yes it's same topology.
Old 2nd May 2013, 01:11 PM   #2059
PetruV is offline PetruV  Romania
What is the advantage of using to3 transistors
Just a kid who likes building and modding things.No inspirational quote here for you
Old 2nd May 2013, 01:13 PM   #2060
R.I.P.
What have you blown up today?
To3 is more resistant to blowing up.
Maybe what you need to suit your building style: switch on and hope/pray/have faith.
regards Andrew T.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
