Olafk,
you have no connection from 2sc5200 emitters to output. At least i can t see it.
best regards
zoky2
http://sl.pons.com/prevod/angleščina-slovenščina/at
best regards
zoky2
Olafk,
best regards
zoky2
It is usual to take a thick wire, because not to make the PCB unnecessarily big.
regards Olaf
@olafk very good layout , nice compact design .....
I think just a few members like my PCB rev 1.1 so I decided to try all in line OT for A23 so here it is .....but not tested !
Regards Alex
I like PCB rev 1.1 and this all in line is nice,
That's very cool ! I like your PCB's.
regards Olaf
picture: A33, some corrections
Thanks to Sonal Kunal.
Nice PCB,
I see ,it is like doing on some AX amplifiers early on this thread. Good to know.
zoky2
It also goes without wire .
regards Olaf
regards Olaf
A33 look simple on this pcb,
Hi Olaf you know more about PCB design that me, but I've been told its better to move the speaker out terminal close to the NFB resistor track on the left hand side of the PCB where the 470R resistors connect to the output trace.
Thicker traces will also make toner transfer easier.
I'm not sure how important this is, but just some advice that was given to me.
Hope I'm not out of line making comments.
Thanks for the advice. Every time really very welcome.
It is only the very first version to get a test. All the points that you mentioned, still need to be considered in the final version.
But after a last check I could not wait any longer
regards Olaf
Today was a good day for me , one board it's almost done ,missing two resistors and one capacitor ......
Regards,Alex
Nice work,
Hot PCB! Looks very professional!Just finished placing components yesterday, there are mistakes further revision needed to optimize pcb.
Regards, Sonal
regards Olaf
Regards, Sonal
Nice pcb, what size it is?
- 100W Ultimate Fidelity Amplifier
