100W Ultimate Fidelity Amplifier
Old 22nd February 2013, 12:19 PM   #1851
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
100r 2W should send smoke,at that place you should place about 20R 5 - 10W with voltmeter connected in parallel so that you could monitor the voltage across the resistor. it may be that bias trim. was set to adjust say 250mA of current so 100r and 250mA would produce 6,26W and 25V at that resistor,but on 20r that would be 1,25W and 5V on voltmeter.
Chop your own wood and it will warm you twice
Old 22nd February 2013, 12:35 PM   #1852
olafk is offline olafk  Germany
You are right. I will test it on the weekend. I had lately only little time for hobbies.
regards Olaf
Old 22nd February 2013, 12:56 PM   #1853
cjkpkg is offline cjkpkg  United States
Originally Posted by apexaudio View Post
with this circuit add to AX14 no need to set bias and no need for bias transistor on heatsink with outputs.
I am still learning - so forgive the noob question but is this auto bias scheme "fixed" or "variable"?
How do you set the target value?
Old 22nd February 2013, 01:33 PM   #1854
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Bias is fixed but you can change resistor 3k3 with 3k6, 3k9, 4k3... to set target value.
Old 27th February 2013, 09:45 PM   #1855
mrdevil83 is offline mrdevil83  Romania
Hello apexaudio.
Can you give me some advice in what transistors i can us instead of the mje340/mje350 pair?
I can't find this transistors (the mje 340 i found only at my local parts store)
I tried using BD139/BD140 but the amplifier distorts a lot at even about 10% of the ouput power.
So i have mounted some KTA1023/KTC1027 found in an auto amplifier.
the 2sc4793/2sa1837 (can't find them either) i have replaced with bd243c/bd244c.
The suply voltage i am using is +/- 42v.
Thanks.
Old 28th February 2013, 09:27 AM   #1856
apexaudio's Avatar
Originally Posted by mrdevil83 View Post
Hello apexaudio.
Thanks.
There is some eror on your amp, it must work with BD139/140 and BD243C/244C.
Old 28th February 2013, 09:24 PM   #1857
apexaudio's Avatar
D12 made in Serbia
Old 2nd March 2013, 07:34 PM   #1858
OK I changed out the PSU I etched in favor of peter Daniel's universal PSU with vishay GBC rectifiers. 22,000uF x2 per rail and voltage has settled in at about 42.
I decided to try biasing the crap out of it and have been running 1.6A per channel for a couple hours and holy cow this amp ROCKS.
Preamp is an aikido 6cg7 input 5687 output.
The iPod, vinyl, and satellite music all sound fabulous.
I will have to debug my diy PSU...I thought it would have been quiet but it hummed like a mutha.
Old 2nd March 2013, 08:06 PM   #1859
Do you use wire jumper?
Amplifier is running. I made the complete wiring (PSU, Amp...) new and had to changed R16 from 1k to 1k5 to adjust the bias. Layout seems to be correct.
regards Olaf
Old 3rd March 2013, 06:08 AM   #1860
panggih is offline panggih  Indonesia
Mr, Mike ax14 I've completed three times, but I have a problem, when I turned, shouted directly ax14 mixed humm.please help me.
ax14 mine exactly with this picture.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
