100W Ultimate Fidelity Amplifier
Old 6th February 2013, 07:46 PM   #1821
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by sonal kunal View Post
I connected amp in series with 10Ω resistance, when nothing seems to burn I put fuse and tried to adjust bias but was not able to, even winding trim-pot to full. Amp was playing music but with crossover distortion at low volume.
Nice work, replace 1k resistor (base-colector BD139) with 1k5 and you can set bias.
Old 11th February 2013, 03:14 AM   #1822
ahmadfay is offline ahmadfay  Indonesia
ahmadfay's Avatar
my ax 20 with 5 pair
Old 11th February 2013, 05:37 AM   #1823
Hadighorbani is offline Hadighorbani  Iran
hi sir mile
i want use this OCP shematic for another amp
i use AX12 in my car with + -30VDC
http://upload.tehran98.com/img1/mwlg...7im5mcuknf.pdf
i want use this shematic for a class AB OCP section
my supply voltage will be + - 35 VDC in this amp
can i drive a relay with S output pin ?
my relay is like AUD600 power section relay
it must protect in 3A and when the out put is shorted
which one off resistors must be change ?
thanks
Old 11th February 2013, 07:46 AM   #1824
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
hi sir mile
thanks
You can find PSU with protect in this thread post #95. This PSU have DC, OC protect and clip leds.
Old 11th February 2013, 07:48 AM   #1825
apexaudio's Avatar
Nice work, what about sound?
Old 11th February 2013, 03:39 PM   #1826
thanks
but i want creat OCp only and simpel like my link
is it work in OCP section ?
Old 12th February 2013, 01:33 AM   #1827
ahmadfay's Avatar
sound quality is very clear (thanks Apex), almost like B500, but the power is much greater. Future I will make tripple darlington B500 version, pcb driver is ready, just plug components.
pray for good luck, regards
Old 13th February 2013, 04:36 PM   #1828
shravanth is offline shravanth  India
MY all new apex AX-14 for 5.1 channel
5 channel Ax-14
SR200 for subwoofer
Old 13th February 2013, 04:38 PM   #1829
AX-14
Old 13th February 2013, 05:12 PM   #1830
apexaudio's Avatar
5 channel Ax-14
SR200 for subwoofer
Nice work.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
