Old 18th January 2013, 03:09 PM   #1811
apexaudio's Avatar
Originally Posted by cjkpkg View Post
Here is a pic...The speaker protects are not hooked up yet but it did not thump at all upon startup or shutdown.
Nice work, and nice picture. I suggest to revert positions of transformer and PSU and you have short wires instead long from AC input to the transformer and from transformer to PSU. Bias transistor (BD139) must be connect on heatsink with outputs.
Old 18th January 2013, 03:43 PM   #1812
davidus is offline davidus  Armenia
Hi, mr. Slavkovich.
Are there any changes to be done with parts if I want to use your PSU-5 design with +-36V AC?
Old 19th January 2013, 12:40 AM   #1813
Originally Posted by ahmadfay View Post
hi all,
why ax 20 which I have made the volume more slowly than the ax14, if this is so the character of ax 20 (ax 14 TEF)?
thanks
Apex hai ...
what is my post? is there any comment from you? thanks
Old 28th January 2013, 07:51 AM   #1814
mr apex.., good advising! i am going to use my stock mj15015s and '016s in Nazirdigi's 4 pairs ax20. as i read the MJ's pdf online i knew its less powerful than what they are using here as powers. i am planning to maximize as possible the supply voltage to its safe extent. what can you advise? thank u vry mch sir.
Old 28th January 2013, 07:54 AM   #1815
@Nazirdigi.. congrats for your vry successful 4 pair ax20 and its protect.. can u post here their pcbs for printing? i thank u much in advance..
Old 28th January 2013, 07:58 AM   #1816
btw expert friends, i am planning also to make an amplifier for my lead guitar. can this also be excellent? i am going to have this in a single channel and i think a pair of outputs is enough. thanks to u all
Old 2nd February 2013, 06:56 PM   #1817
Hi miles, I assembled AX-20 amp I have attached layout. Problem with this layout is, there is no connection between Q9 - Q18 and Q8 - Q17. I easily fixed by using MJE340-50 lead as jumper at copper side. My problem is I am not able to adjust bias, amp is playing music every thing seems right.
Old 4th February 2013, 05:51 AM   #1818
hi, Sonal Kunal
if you look at the scheme, there will be a dc current that comes out on the speaker output, because there is one diode 'IN 4007' an inverted installation, the voltage of the diode is positive. you try to watch another scheme,
Old 4th February 2013, 10:55 AM   #1819
yes thats in layout but in board I have place correctly, there is only 10-15mV dc at output. I'll post picture soon.
Old 6th February 2013, 05:06 PM   #1820
I connected amp in series with 10Ω resistance, when nothing seems to burn I put fuse and tried to adjust bias but was not able to, even winding trim-pot to full. Amp was playing music but with crossover distortion at low volume.
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2013 diyAudio
