100W Ultimate Fidelity Amplifier - Page 179 - diyAudio
Old 30th December 2012, 05:01 PM   #1781
hello friends plz help me in post #1755
Old 30th December 2012, 07:06 PM   #1782
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Would you please refine your question?
That capacitor looks to be some sort of ground lift. Maybe someone can explain its behavior in this circuit.
Max.
Old 30th December 2012, 07:35 PM   #1783
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Exclamation pay attention
hello sir I made AX-14 amp
Is I should connect 0.1uf capacitor from power supply ground to input ground
No need for any capacitors.
Almost all apex amplifiers are to be connected as on next picture:
(the SGND (signal ground) from pcb goes to input conector and from input conector it goes to power GND . that is how it goes for both(all) chanels in amplifier chases,each for it self. this is a scheme for AX12 but the same principle is used in (almost) all other APEX amplifier wireing)
Old 30th December 2012, 07:47 PM   #1784
Greg Erskine's Avatar
Originally Posted by AndrewT View Post
Nazir,
follow the circuit schematic. It tells you the voltage at the base of the -IN transistor.
Look at the emitter of the +IN transistor.
Follow the DC current route through to Signal Ground (SG).
From this route all the current flows in the same direction from emitter to SG.
The emitter and every component MUST be +ve with respect to SG.
Now look at the base of the +IN and compare it to the base of -IN.
Thye voltages at these two bases should be IDENTICAL if the two transistors are IDENTICAL.
The base of +IN MUST be +ve with respect to SG.
Learn to read the schematic !!!!!!! READ !!!!!
Or C6 is incorrect. But I think we have discussed this many times in the past and because there is very little voltage across C6 it doesn't really matter. I would like to see it corrected so it can become an accurate reference for future builders.
Andrew, I think Nazir may be able to read schematics that is why he is asking for it to be checked.
Greg Erskine
Old 2nd January 2013, 10:54 AM   #1785
thank you sir can u suggest any bass treble board for ax-14
Old 2nd January 2013, 11:02 AM   #1786
Vostro is offline Vostro  South Africa
Vostro's Avatar
Apex Tone control.
http://www.diyaudio.com/forums/analo...ml#post3072964
Old 2nd January 2013, 12:38 PM   #1787
AUDISOUL's Avatar
Default need pcb help
Originally Posted by alex mm View Post
........ I have from now a huge colection of Apex amplifier schematics and ofcourse many PCB's designed....... and another one
Alex.
Hi alex please send me pcb design of this project
My ID audisoul@yahoo.in
Old 2nd January 2013, 01:45 PM   #1788
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Default NTC 10K
Mr. Mile,
NTC 10K is not available in my place, what are the recommended value can be use instead of 10K??
Willj78
File Type: jpg APEX%20Stereo%20Speaker%20Protect_0000.jpg (259.1 KB, 1152 views)
Old 3rd January 2013, 01:53 AM   #1789
hi apex sir,
pls clarify the 1762 post.
Old 3rd January 2013, 08:26 AM   #1790
Hello,
I'm thinkig about building an AX14 amp. Any advice on how to drive it with a balanced source? can i feed a balanced signal to the differential pair in the first stage?
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2017 diyAudio
