#1311 |
Can i use ax-14 for PA application with two pairs of outputs with +/-65dc @ 8 ohms load
#1312 |
can i use ax-14 for pa application with +/-65v at 4ohms, how many pairs of output transistors to be used?
#1313 |
Use 3 pairs of output transistors.
http://www.facebook.com/APEXaudio.MileSlakovic |
#1314 |
I think there is no pcb for three pairs of outputs to this ax-14 can i use sr200 for PA it has three pairs of outputs and also need good sound quality sound even for PA speakers,does it fit for this purpose or shall i use ax-14 anyway please guide me
#1315 |
Use SR200 it's give best sound quality for any purpose.
#1316 |
In post #1284 you can find pcb design for AX amp with 3 pair of outputs.
#1317 | |
but there is no protection to it in the pcb can i add b500 protection ckt to sr200 there are so many versions of pcb of sr200 which pcb is to be used can you please suggest me thank you |
#1318 |
Thank you Mile but i decided to use sr200 as you stated of its quality of sound and performance
#1319 |
Hello
How does the generated negative voltage in the circuit message number 704. Thank you. Regards, Dmitri, Ukraine, Dnepropetrovsk. |
#1320 | |
Mam pytanie, gdzie można kupić duże radiatory aluminiowe ?
Last edited by wintermute; 17th May 2012 at 10:40 AM. Reason: added translation. |
| Good ~100W amplifier | percy | Solid State | 16 | 3rd April 2013 05:16 PM |
| New desined 4*100W car amplifier | Whortless | Car Audio | 13 | 21st July 2011 04:39 AM |
| Ultimate Amplifier | DF Plummer | Tubes / Valves | 19 | 23rd March 2011 02:48 AM |
| Ultimate amplifier | glen65 | Car Audio | 2 | 19th September 2007 02:15 PM |
| 100W Amplifier Shematic and PCB | viki | Solid State | 2 | 17th October 2004 11:54 AM |
