Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#121 | |
66Vx10A=660W, and your amplifier will be 75W/4ohm with +/-33V rail voltage, 150W for both channels, with 70% eficiency of AB class you need 200W from PSU minimum, I recomended 300W, but 10A rectifier will be OK. Regards |
#122 |
With 2x24v ac I use this amplifier:
TDA7294 Stereo/Bridge with PSU |
#123 |
AX14 also can work on +/-33V DC with same performanse and 75W/4R output power, I recomended TDA7294 just for begginers.
#124 |
i will put the 8A rectifier and test the psu.but im afraid it will get too hot even at 4 amperes.
do you have tone control circuits?i would like to have one. |
#125 | |
http://www.diyaudio.com/forums/solid...q-preamps.html Regards |
#126 |
thank you.
by the way, do you have one pair output amplifier design with opamp at the input? do those amps sound good or is it better to have discrete components at the input instead of opamps? |
#127 | |
Here is schematics of B50 with single darllington pair outputs. |
#128 |
apex,
does this nchannel design has pcb,or where thread this came? |
#129 | |
Regards |
#130 |
apex,
do you have this arcam clone design regards |
Thread | Thread Starter | Forum | Replies | Last Post |
Good ~100W amplifier | percy | Solid State | 16 | 3rd April 2013 05:16 PM |
New desined 4*100W car amplifier | Whortless | Car Audio | 13 | 21st July 2011 04:39 AM |
Ultimate Amplifier | DF Plummer | Tubes / Valves | 19 | 23rd March 2011 02:48 AM |
Ultimate amplifier | glen65 | Car Audio | 2 | 19th September 2007 02:15 PM |
100W Amplifier Shematic and PCB | viki | Solid State | 2 | 17th October 2004 11:54 AM |
New To Site? | Need Help? |
