100W Ultimate Fidelity Amplifier - Page 12 - diyAudio
Old 20th May 2010, 11:15 PM   #111
apexaudio's Avatar
I must find and share newer version of this PSU with soft-start for transformer and 35A bridge rectifier on PCB.
Old 25th May 2010, 02:19 PM   #112
maouna is offline maouna  Greece
it would be quite useful...
Old 25th May 2010, 08:57 PM   #113
apexaudio's Avatar
I like to see pictures of builded PSU or amp, this is reason for share, and I will post what you want from my arhive. I have lots of my old projects, and I want post only most useful for diy.
Old 25th May 2010, 10:31 PM   #114
here is the psu ,but without the overcurrent protection parts.ithis space i want to put the 35Α bridge rectifier
Old 25th May 2010, 11:26 PM   #115
apexaudio's Avatar
Put the 35A bridge rectifier on case and connect with wires from pcb. Overcurrent protection is very adventage circuit and I suggest to use it, this short circuit protect cut out speakers even at low volume level, you can use amplifier without rail fuses and VI limiter with this protect safely.
Old 26th May 2010, 01:17 PM   #116
the overcurrent protection at your design ,only checks current at positive rail.what about negative rail ?isnt it necessary?
Old 26th May 2010, 02:04 PM   #117
apexaudio's Avatar
No, audio signal is AC current from 20Hz to 20000Hz, there is 20 peak current per sec minimum, and it's simetrical in positive and negative rail, it's not necessary checks current in both rail like with DC current.
Old 27th May 2010, 01:58 PM   #118
apexaudio's Avatar
Can you post picture in high resolution?
Old 27th May 2010, 02:10 PM   #119
apexaudio's Avatar
I find this
Old 27th May 2010, 07:39 PM   #120
this is the best i can get with my phone camera .its night here now.
i havent tested the psu yet.i will connect the 35A rectifier and put back the short circuit protection.
do you suggest 0.22ohm resistors for short circuit protection ? i am using a 24-0-24 volt /200VA transformer which is +-33 volt dc after rectification and smoothing capacitors.
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
Copyright ©1999-2017 diyAudio
