100W Ultimate Fidelity Amplifier
Old 16th April 2018, 06:35 PM   #10261
olafk is offline olafk  Germany
It is long ago. I do not think 50k is a good idea. If I remember correctly, the pot is in the feedback loop. I do not know how it changes the gain.
Also may be that the potentiometer has to be mounted on the copper side to gets louder when turning to the right. Sorry for incomplete information.
Old 16th April 2018, 07:05 PM   #10262
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by mantrieSolder View Post
can i substitute the pot.5k with 50k because in my country this part is so hard to find it.
i am sorry my bad english.
regard mantrieSolder
You can not use 50k for A2 preamp but you can use it with TB1 preamp.
Old 17th April 2018, 05:34 AM   #10263
Yuriy64 is offline Yuriy64  Russian Federation
Hello Mr. Mile, I sent you an e-mail, but you did not answer.
I want to make a button switch on the amplifier, in the network found this board:
APEX_on_off.JPG — Yandex.Disk
I did not find the circuit schematic, so I drew from the board. Is the circuit correctly formed?
APEX ON_OFF Schematic.GIF — Yandex.Disk
Used this PCB:
APEX ON_OFF LAY6.GIF — Yandex.Disk
APEX ON_OFF LAY6 FOTO.GIF — Yandex.Disk
Result:
1. When i turn on 220V - immediately turns on the load, and the LED is very dim, I probably replace the 1k resistor on the 510R.
2. When I press the button is with an interval of 5 seconds - an uncertain switching, may turn on, or it may not turn on.
3. The transistor BD241 is heated. Does he need a radiator?
Tell me please how correctly the circuit should work, if I drew it circuit schematic correctly, and how to achieve a stable switching?
I'm sorry for my bad english.
I could not add pictures, so I inserted links.
Old 17th April 2018, 06:52 AM   #10264
apexaudio's Avatar
Used this PCB:
Result:
Circuit is correct. Use n.o. push button switch. BD241 must be hot no need to use heatsink.
Old 17th April 2018, 07:02 AM   #10265
Yes, I'm using n.o. push button switch. I do not know how to overcome the instability of switching, and rattling contacts relay.
Old 17th April 2018, 07:44 AM   #10266
apexaudio's Avatar
Switching is stable in this circuit, something must be wrong in your build.
Old 17th April 2018, 09:36 AM   #10267
sanbadgujar is offline sanbadgujar  India
Default need help about AX-14
Hello Apexsir
I make your AX-14 Amp today, during testing amp I got dc offset 40vdc and the same voltage on 0.33Ohm resister.I make all connection as you mention
Connect Input ground to PSU ground, a short input terminal, use 10 Ohm 10w resister instead of fuses. My supply voltage is +/-47Vdc.
What are the problems? please see attached photo and help me.
Old 17th April 2018, 09:44 AM   #10268
prasi is offline prasi  India
prasi's Avatar
Which layout did you use? Check the diode orientation.
If I remember correctly, the original had wrong orientation which was later corrected. Check my layout and sch posted posted in this thread some time ago.
My revamped site https://sites.google.com/site/analogdesign1234/
Old 17th April 2018, 10:48 AM   #10269
Dear prasi
I am using following layout . and I am get -40dc on sp out please help
Old 17th April 2018, 12:20 PM   #10270
alex mm is offline alex mm  Romania
alex mm's Avatar
Originally Posted by sanbadgujar View Post
Dear prasi
I think you forget to connect signal ground from input to GND . See red line in attached picture.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
