100W Ultimate Fidelity Amplifier
Old 10th December 2011, 08:17 PM   #1011
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Dear Mr. Apex,
Unfortunately, my ax-16 has just produced noise and pop up when it turns on on both channels I don't know why? It does never happen before. I measured dc out put but still low.
Please give some advices to solve the problem. Some one told me that there are some parts (small transistors) could be malfunctioned or broken...Could you give me clues which transistor potentially broken?
Many thanks before
Best regards,
Arif
Old 11th December 2011, 09:13 AM   #1012
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
Dear Mr. Apex,
Many thanks before
Best regards,
Arif
Measure BE voltages on small transistrors, must be about 600mV.
Old 14th December 2011, 12:39 AM   #1013
I have replaced all small transistors with new transistors , also all glass diode , but the result still the same. My amp still produces noise and hum, I need your advice. I am sorry I forgot to measure BE voltage...Could you tell me the purpose of measuring BE voltage? I will do it soon.
Thank you so much...
Old 14th December 2011, 08:09 AM   #1014
apexaudio's Avatar
Connect GND from PSU to the input terminals, from input terminals to case, discconect amp gnd from input gnd on amp pcbs and add zobel network on speakers terminals ( 10R, 100nF)
Old 15th December 2011, 12:17 AM   #1015
Many thanks...Mr. Apex...
But these noise and hum never happened before. It run very great before with that lay out for months, and I like the sound so much. It happened first time only for left channel, and the other channel went the same. I think some parts may be in trouble.
Old 15th December 2011, 09:19 PM   #1016
apexaudio's Avatar
Add zobel network on speaker terminals, with EI transformer instead toroidal HF instability is possible.
Old 15th December 2011, 09:38 PM   #1017
apexaudio's Avatar
I also suggest to use my pcb design (AX14) for better stability
Old 16th December 2011, 12:20 AM   #1018
Dear Mr. Apex,
Which kind of wattage rating for 10R on Zobel Network? 2 watt?
Any sound quality differences between AX14 compare to the AX16? because I like AX16 much.
Many thanks...
Old 16th December 2011, 05:17 AM   #1019
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Originally Posted by apexaudio View Post
Pcb must be design with 'star' for ground 'star' for output, and rail tracks after decoupling caps, feedback from output 'star' to input... You have right for your tracks, but pcb is better to be smaller as posible.
Thanks to Apex,
You really save me...
I hope this one is okay to continue
if not okay yet, I will make new design again...
If okay I will made it soon
Hi Arif,
sudah cek PSU belum, kayaknya kapasitor atau elkonya yg masalah
Thank you, I wish you happy
peace & G B U
Old 16th December 2011, 05:56 AM   #1020
Originally Posted by JOHN BALI View Post
Thanks to Apex,
Hi Arif,
Hi John Bali...
I have checked all the supply caps ...fine. Also I changed with other supply from another amplifier ... still get the same noise and hum...
many thanks for your idea...
Best Regards...
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
