100W Ultimate Fidelity Amplifier
Old 6th December 2011, 08:44 AM   #1001
Thabto is offline Thabto  Italy
In post #995, you mention of an AX17S v2; Is it any different to the PCB in post #994? If so can I have the PCB of AX17S V2, I need to etch it. Also, may you please give me Power PCB / Schematic. What transformer should I use If I want to power 2 AX17S V2 for stereo sound. Thanks.
Old 6th December 2011, 10:26 AM   #1002
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Originally Posted by apexaudio View Post
Amplifier must be neutral in sound, for deeper bass use speakers with deeper bass or 'loudness' circuit if you must.
No need to use servo, match transistors and add pot for set DC offset, with DC servo it's easyer (auto set).
Thanks for the reply,
so there are 2 way to set the offset, manual offset with pot & automatic offset with IC.
I will continue my first plan AX17, simplyer no IC
will modified latter to AX17v2 or AX17S or maybe Sir Apex still have another AX17 evolution,...
One think, it is an upgradable amp but we can make AX17 as a start point
Thank you, I wish you happy
peace & G B U
Old 6th December 2011, 11:25 AM   #1003
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Use pcb from post #993, and AX17 can use same PSU and protect as AX14, NX14... or similar +/-45V 5A for stereo.
@ JOHN BALI use pcb from post #993, your pcb is not good for amplifier.
Old 6th December 2011, 12:00 PM   #1004
JOHN BALI's Avatar
So that is the good design, I will compare to mine...
Ok, thanks for your advice... you're so responsible, protect me to not doing any damage, even I'm not doing it yet (I hope not to make it)
I guess because my PCB to small & the output track is spreading everywhere, is that the reason?
But if I make it bigger & short track of output, maybe this way okay?
So I will make 1 PCB to try, will inform if it is fail
& will powering with smaller PSU first, I don't like to fry innocent parts
I will take the risk, its my responsible now
or maybe I will do some revision first
peace & G B U
Old 6th December 2011, 12:52 PM   #1005
apexaudio's Avatar
Pcb must be design with 'star' for ground 'star' for output, and rail tracks after decoupling caps, feedback from output 'star' to input... You have right for your tracks, but pcb is better to be smaller as posible.
Old 6th December 2011, 01:48 PM   #1006
apexaudio's Avatar
For AX17 pcb from post #941 can be use.
Old 7th December 2011, 01:38 AM   #1007
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Dear Mr. Mille S.
which one is better voltage for feeding this ax's series, +/-40(Vdc), or 40-0-40Vac (approximately 56Vdc).
Now I feed 40-0-40Vac, is it still in SOAr?
Many Thanks .
Old 7th December 2011, 07:15 AM   #1008
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
Dear Mr. Mille S.
Many Thanks .
For 8 ohm speakers you can use +/-56Vdc with single pair of outputs, for 4 ohm add another pair.
Old 7th December 2011, 07:45 AM   #1009
Ok thank you so much for your advice.
Best regards,
Arif
Old 10th December 2011, 02:52 PM   #1010
vorezky04 is offline vorezky04  Indonesia
Where protect rotect as AX14, NX14 mr???
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
