100W Ultimate Fidelity Amplifier
Old 11th November 2017, 12:12 AM   #9991
trebolo is offline trebolo  United States
Default PCB's
Hi I want to make some of apex's amps for myself. Can I buy pcb's somewhere. Or can I get pdf's of the copper so I can etch myself? I have read through most of thread and may have misssed it. I like the fx8 and a few other small ones especially
Old 11th November 2017, 03:32 AM   #9992
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
There are several Gerber files posted for FX8 (as well as many other amps). Send those Gerber files to one of the Chinese board houses and you can buy 10 for $2 plus $20 shipping via DHL to US. It may cost less to other countries. India is $8 for example. There is a thread called Index of Apex amps. The directory in that thread will give you links to locations of Gerbers. Many amps also have pdfs of copper traces and you can do your own etching at home.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th November 2017, 09:35 AM   #9993
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 100W Ultimate Fidelity Amplifier
Default 1000 pages!
Max.
Old 11th November 2017, 09:49 AM   #9994
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Default Uno Mille
Mille Grazia
send from my NOTEBOOK PC.
Old 11th November 2017, 12:39 PM   #9995
prasi is online now prasi  India
prasi's Avatar
Build the APEX FX-8 Bimo mod as reported by xrk and others.
Its already posted in thread , both gerbers, and diya pdf files. here
you can send the gerber zip file to any of the chinese board houses wihout facing any issues.
Schema here
bias procedure
Procedure for bias.
1. you will need 2 nos. of 10ohm 1W/2W resistors.
1a. turn the trim pot so that resistance between first and third leg of trimmer is approx 250 ohm.
2. Connect one lead these 10ohm resistors in series with your + and - rail wires of psu.
3. connect the other lead of resistors to amplifier +/- supply connector on amp pcb.
4. switch on supply and measure the voltage drop across these rail resistors.
4a. measure the voltage between spk out and ground. this is offset. it should be less than +/-30mV. Good matching of Hfe of i/p transistor pair (Q1/Q3) will ensure that offset is close to zero.
5. total quiescient current is given by I= V/10ohm
6. set the pot so that voltage drop across 10 ohm rail resistors is about 1V to 1.1 V.
7. Let the amp warm up for 1/2 an hour recheck the bias
8. Adjust pot if required to have voltage drop of 1 to 1.1 V.
9. This will ensure that you get a bias through o/p stage of approx. 100mA.
let me know, if you need anything else.
My revamped site https://sites.google.com/site/analogdesign1234/
Old 11th November 2017, 12:43 PM   #9996
prasi's Avatar
Originally Posted by smartx21 View Post
wonder who will be posting the 10,000th post, lucky him!
long live "100W Ultimate Fidelity Amplifier"
Old 11th November 2017, 12:57 PM   #9997
Got Foam?
xrk971's Avatar
For the adventurous, the FX8 Bimo runs superbly at 1.2amp bias current and 24v rails for pure Class A up to 16wrms. That's what I am running now and it's great sounding. Winter is here and I don't mind having some extra heat in the lab to keep things comfy
Old 11th November 2017, 01:01 PM   #9998
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
When this thread passes 10,000th post it's time for the next level... "10,000W Ultimate Fidelity Amplifier"
Have a good weekend everyone around the globe!
Old 11th November 2017, 05:40 PM   #9999
Thanks for the reply, I am making a couple FH9 this morning since I found the PDF's from Sonal Kunal. Thank you Sonal for the hard work. And the rest of the group. This truly is a unique post. I am surprised its not in a separate forum. I will be sending off some gerbers soon. I am just making sure I send the correct ones. The directory of Apex is great! I will be posting my Apex amplifiers as soon as I get something interesting going here! One more makes 10,000!!!
Old 11th November 2017, 05:49 PM   #10000
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
10000 all the best to all that contributed to this thread specialy to Mile Slavković: thank you for all that you have given to support DIY community all around the world!
Chop your own wood and it will warm you twice
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
