Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. - Page 126 - diyAudio
Old 29th January 2011, 08:10 AM   #1251
niss_man is offline niss_man  Australia
Originally Posted by destroyer X View Post
He said never listened so nice sound to guitar or music.
regards,
Carlos
I bet many people have said this. Including myself. Carlos, what are your plans for your next amplifier design?
Niss_man
Old 29th January 2011, 09:13 AM   #1252
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default No, i have no plans about.... it seems to me i cannot make better than the best to my
ears... so long time searching and listening and testing and assembling amplifiers...i found the one!.....i doubt i can make better.
I am playing with speakers crossovers and confirming my thougths:
- A hell to the flat... sound must be good to my ears, beeing flat or not flat (instruments problems not mine)...must take in account my my home acoustics, my home ressonances and my musical taste.... must use an amplifier without tone controls and not feel bothered with sonics.
I have discovered interesting things about speaker crossovers...and will produce a video and you will have the link Simon..also other close friends.... some tricks about where to pick the treble in the passive crossover, how to produce loudness contour to listen low power, the mid range issues and special inductors to the woofer....how to perceive extremelly ballanced sonics and to perceive when each driver are playing in separate..without mess the whole thing with a single source of music from "the box".... now i can perceive each driver when entering in action....you know...finishing with the hell "milk shake".... when you cannot feel the milk, the suggar and the chocolate..the idea is to perceive each one of them in separate without be mixed in a mess of things with a resultant taste that is not milk, not chocolate and not suggar... to listen three women singing and to be able to perceive each one of them clearly..without that harmonic resultant...when seems a single voice with electronic stuff repeating the same voice three times with some delay.
- Also playing with meters, or ligth indications....i want transistorized, discrete, and if you have three leds..measuring 10 watts, 40 watts and 160 watts.... then i want the 10 watts one to go off (led off, dark, no ligth) when reaching 40 watts.... i am working on that and feeling i got some tricks about....of course i do not want chips..it is the maximum possible of lack of creativity and imagination to assemble already made things inside a chip...aaagh!... to build using chips it is better to buy already made things.
- Also trying tone controls to my daugthers, as they need that and asked me that...i do not like them..noisy, distorters..awfull things...but working to obtain the best possible solution...i think i found one...working on it.
No more hard work to uncle charlie...others should offer amplifiers...this takes too much time, planing, research, building, tests, some torture and need our continuous follow up.... some guys bothers a lot when see others working and there are much more suggestions than people moving their hands to do real things...i do think i made my part of this stuff to the communitty, it is time to others to work hard.....now i am listening, having pleasure....working only to give some follow up and help to the last group buy builders..the blue board builders.... so, my activities will reduce till almost stop...i am going to the audience...not more on the stage.
regards,
Carlos
Old 29th January 2011, 10:13 AM   #1253
ostripper is offline ostripper  United States
ostripper's Avatar
Originally Posted by Pingrs View Post
A common solution as given by Stochini (EE May 1983) and later Doug Self but an improvement, mentioned by others (inc Andrew T), is to split the VAS degen to ensure premature operation of the protection device doesn't arise at any turn-on voltage.
I modified my "DX-Precision" as shown.
Brian.
Yes , the leach amp does it this way. Referencing a 47R VAS degeneration resistor gives 12.5mA - 33R=21mA - 22R=27mA (Cordell's example). With my low current 6.1mA setup , the 12.5 is quite enough.
Like Carlos , I never had any issues with the beta device (Q6) besides a little warmth. I added the extra device just to make "damn" sure.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 29th January 2011, 10:42 AM   #1254
Well said Carlos. Well said.
Simon
Old 30th January 2011, 10:59 AM   #1255
Default I have asked Renatovsky Kalishinikova to torture the Dx Blame ST
Using a BC546 as original in the first VAS stage...and survived.
I have asked him to saturate the input with three times the level needed to drive the power amplifier to it's maximum power...to use 4 ohms and standard power supply...so...overdrive was used and survived!
So, if you keep it will work fine this way..if you want even more safety, then replace Q6 by a 2N5551 or even a BD139.
YouTube - Dx Blame ES "O Amplificador de Ferro ll"
I am uploading video about the " L " adaptor Issue.... this adaptor made in Brazil is NO GOOD!
regards,
Carlos
Old 30th January 2011, 12:35 PM   #1256
Default The " L " adaptor issue to the Dx Blame amplifiers
These " L" adaptors are not used only by Brazilians, but it is suggested to everyone to use this style (when have not the natural flange in their heatsink):
YouTube - The adaptor issue 1
YouTube - The adaptor issue 2
regards,
Carlos
Old 14th February 2011, 02:08 PM   #1257
robydream is offline robydream  Croatia
hello...everybody....i im currently making an order from mouser...and need Your help:
they don't have Nichicon KZ in Stock following values: 2pcs 4700uF/50V and 2pcs 10000uF/50V...so could i use Nichicon KZ 4pcs 8200uF/50V ?
for use on DX Blame ST board i will use Vishay/Dale RN60D 1/4W and RN65D 0,5W resistors...for DX PSU boards they dont have RN60D in high wattage...so could i use following models:
R1, R2 5K6 +/-5% 2W Vishay/Dale (CPF25K6000JKB14)
R3, R4 0R47 +/-5% 3W Vishay/Dale (CPF3R47000JNB14) 3W instead of 2W for CR filtering
R5, R6 3R3 +/-5% 3W Vishay/BC Components (PR03000203308JAC00)
R7, R8 2K2 +/-1% 2W Vishay/Dale (CPF22K2000FKE14)
It's hard to find 1n5/63V to 100V MKP(becuse of big dimensions) so i use EPCOS 1n5/100V MKT... i think that not using MKP in DX PSU board dont have any difference in sound quality?
Many thanks
Old 15th February 2011, 09:06 AM   #1258
astankov is offline astankov  Bulgaria
astankov's Avatar
Hi Carlos!
I'm planning to build Blame Es and I have several questions:
Will be a problem to increase the input sensitivity by increase the value of R13 from 12 to 15K Ohms. Will this affect the stability of the amp?
I will use the amp with +/- 33V DC. Do I need to change some of the values of the resistors in the schematic?
Thanks.
Old 15th February 2011, 12:48 PM   #1259
Default No dear Astankov, you can tweak R13 and R2..but make them almost the same value
These resistances, in special R2, in the input, from base to ground, is the one you can understand as the input impedance...say..input impedance is not too much different than it's value.... R2 beeing 47K, then input impedance is almost 47K..... R2 beeing 10K, then input impedance is almost 10K.
I have perceived that 10K works better...also i could notice that 12K (R13 having 20 percent bigger resistance compared to R2.... resulted better in sonics and worse in off set).
The gain ratio depends on R13 divided by R2.....but...... we have gain one, or almost one in this case... BUT.... we have something that change that...the resistance to ground (in series with an electrolitic condenser) that controls the gain...so, now you divide R2 by that resistance..... and the one is R7.
R7 adjusts sensitivity..it is 820 ohms to 1 Volt peak input (700 mv rms aprox.)...and this way you will have full power in the output....but you can REDUCE it to increase the sensitivity.... i have used 390 ohms to plug this same amplifier into a satelite receiver (International Broadcasting reception)...so.... increase your sensitivity reducing R7 instead to tweak R13 and R2....but off course this unballances gain too and produces increases in gain too...but it is easier, and less harmfull if you tweak R7.
No, no need to change resistances because of less voltage in your supply....this amplifier operates without any modification (tested) from 12 plus 12 volts till 44 plus 44 volts....anything to change on it.
regards,
Carlos
Old 15th February 2011, 03:08 PM   #1260
astankov's Avatar
OK! I understand you I won't touch R13.
I will change R7 to 390R now the gain should be enough for me and you did that also but will that affect sonics in some way? If affects the sonics I will use a preamp.
Thanks again for your response. It was very helpful to me.
Best regards.
Andrey.
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please.Hide this!Advertise here!
The Drek builder's thread cviller Pass Labs 412 25th September 2011 12:25 AM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx amplifier, builder's thread destroyer X Solid State 25 31st May 2009 01:53 AM
Copyright ©1999-2017 diyAudio
