Old 5th July 2010, 05:02 PM   #151
destroyer X's Avatar
Default Too much big to be uploaded Kanwar
Also i have no Brazilian music in Flac format...the one may have is Mr. Professor.
I have one, but was traditional PCM format (wave)...and the one is even bigger.
My upload speed is slow.... maximum of 100 kbps.... the upload speed is 10 times bigger.
To send Flac or wave, represents 30 minutes of upload. (average)
regards,
Carlos
BTW... is really you that is using Workhorse nickname?.... you seem different.... or your brother, or even Sami is using by you?
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0
Old 5th July 2010, 05:05 PM   #152
Workhorse's Avatar
Okk Carlos
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 5th July 2010, 05:39 PM   #153
Default My internet, dear Kanwar, also does not attach files bigger than 25 megabytes
So, i have tried but i could not.
Wave files and Flac files, usually are bigger than 50 Megabytes.
Quality difference is huge..... Flac is much better than MP3 320K
I have no FTP adress to send you computer to computer.
regards,
Carlos
Old 5th July 2010, 05:42 PM   #154
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Nice pics of the DIY Brazil event carlos .............
Old 5th July 2010, 08:15 PM   #155
Default Thank you Wayne..... by your interest to see my videos
Thank you,
regards,
Carlos
YouTube - DIY Fest Rio 2010 - Dx Blame ST
YouTube - DIY Fest Rio 2010 - Farjon fotos
Old 5th July 2010, 11:51 PM   #156
Default This brazilian friend made Dx Blame test using DAC and a pré amplifier
A tube pré amplifier called Aikido.
His name is Hudnes, he lives in Maceio, Capital of the state of Alagoas.... Northeast of brazil too... this state touches mine, has border with Pernambuco at south of my place.
YouTube - MY DIY STEREO, DX BLAME ST, AIKIDO
Video is not fine...but audio is nice.
enjoy,
regards,
Carlos
Old 8th July 2010, 07:17 AM   #157
Dear Carlos, Is it possible for me to use +-25VDC for Blame ST, I don't need the full power from the amp, I guess with 25VDC I will get around 50W in to a 8 ohm Load (Which will be very very Loud) with this amp, Am I correct.
Old 8th July 2010, 08:55 AM   #158
Originally Posted by zeraphine View Post
Am I correct.
no.
A 50W into 8ohm amplifier must output 20Vac to an 8r0 load. P=Vac^2/R
The peak voltage will be 28.3Vpk.
You will lose ~2V through the amplifier so the PSU should supply ~+-30Vdc, when fully loaded, to the amplifier power terminals.
The PSU voltage will rise ~4V when unloaded. Expect the PSU to be ~+-35Vdc for a 50W amplifier.
If you start with +-25Vdc, then maximum power is likely to be 20W to 25W into 8r0.
If you listen to average levels of ~-20dB ref maximum power then your 25W amplifier will be delivering 250mW to the speaker when turned up to maximum with that 20dB overhead to prevent clipping of peak transients.
Old 8th July 2010, 10:33 AM   #159
Originally Posted by AndrewT View Post
no.
That's so informative, thanks so much andrew
Old 8th July 2010, 10:33 AM   #160
Default Yes...Andrew is right about the technical point of view
In the reality, audible difference when you compare a 25W amplifier with another one with 50W output is not clear..not huge....not easy to perceive...so....will play loud as you have imagined....about they can play loud and powerfull using 25 volts?...the answer is yes.
regards,
Carlos
The Drek builder's thread cviller Pass Labs 412 25th September 2011 12:25 AM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx amplifier, builder's thread destroyer X Solid State 25 31st May 2009 01:53 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
