Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. - Page 116 - diyAudio
Old 1st December 2010, 10:04 PM   #1151
destroyer X's Avatar
Default I am glad to know that dear Dexter
Thank you,
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 2nd December 2010, 12:21 AM   #1152
Mamak is offline Mamak  Malaysia
Originally Posted by destroyer X View Post
Thank you,
regards,
Carlos
if i still using 2sc5200 for supercharged amp.can i still get 200 watt output power?
Old 2nd December 2010, 03:38 AM   #1153
Default Yes, no problems with music, because music is average in power
But avoid to push the amplifier to the limits for long time with constant signal (generator, organ, microphonic sounds) and similar sources of continuous tones into full power.
If your music style is constant, and if you use to push your amplifiers into the limits, or even appreciate to drive it to distortions, then you should use the transistors pointed as ideal.
The difference is that you may be able to destroy if you decide to do it using 2SC5200 and 2SA1943, when with the units pointed the amplifier will be much more safe..... keep it cool, use good heatsinks, big sized ones or use fan blower to help you.
These things are always a compromise...if you want or need to use 2SC5200 and may push the amplifier to the limits, or even above (clipping), then it is better to install another extra pair of power transistors.
Was made this way to be economic, to save space and to save your money, but you cannot make too much excesses with it.... a 4 ohms speaker that may have some impedance valleys when impedance fall beyong 4 ohms can kill this amplifier if you force it above the distortion threshold.... say, if you drive it with square wave, with several volts in the input and for too much long time while using undersized heatsinks....well.... it can be destroyed..for sure it is not an undestructable amplifier.
So, you decide to be in the safe side or not... safest side is using the original suggested transistors and not using speakers with impedance that fall below 4 ohms...and sadly, some of them are this way...so.... use 8 ohms with your 2SC5200....it will be better.
With as single pair, mine other amplifiers are able to put out 100 watts continuously, unclipped signal, over 4 ohms loads..... so, it is not too much strange 2 pairs facing 200 watts, as this is a very simple calculation and does not surpasses the limits, or they would burn during my tests..and they did not have burned.
I have other amplifiers that can face strange loads and survive.... Troyan is an example, also the DHR Turbo.... and both of them have threads in this same forum.... also there are others too, from Quase and some others that are not too much different in performance.
regards,
Carlos
Old 2nd December 2010, 04:40 AM   #1154
Default More Dx Blame ST builders
Here is another one.
Some pictures attached and a video too:
YouTube - back loaded horn
In this video he is not using the Blames....they are under construction..he is showing his speaker only....soon you gonna have Blame playing and then you will be able to compare... if recorded using same camera and same music it will be possible to compare.
regards,
Carlos
Old 2nd December 2010, 05:17 AM   #1155
Good to see you back Carlos .
Always good to see another comparison.
Niss_man
Old 2nd December 2010, 05:31 AM   #1156
Default I will ask the guy to produce a comparison as soon as he finishes his Blames
Thank you Niss_man
regards,
Carlos
Old 4th December 2010, 03:57 AM   #1157
Here is a couple of oscillascope readings of my Blame ST at near clipping and also at clipping. Using 100w 7.5ohm resistor as a load. It had 21.7v ac rms just before clipping so therefore 63w at 7.5ohm load.
Niss_man
Old 4th December 2010, 04:22 AM   #1158
mr carlos. In my town, 2sc5200 is cheap and useful for me to build a DIY amp. How can I modified DX Blame ST if I want to add more power output and increase power supply voltage to get more wattage output (around 200-300W), or is there any other way or circuit for me to do it?
For DX Blame SuperCharged, I hesitated to change MJL to 2sc5200 power output, should it won't give me unsatisfactory result. How can I do it without defecting the quality of the sound produced?
Old 4th December 2010, 05:35 AM   #1159
Default Thank you dear Niss-man...nice scope images
Adjusting rail resistances you can have a more symetrical clipping, but, as you know, some assymetrical clipping produces and interesting effect that some folks appreciates.
Mamak...the modified Dx Blame ST version is the Dx Blame Supercharged...so, you already have the model you need.
If you want to use 2SC5200, then try another extra pair of power transistors..do not forget to use an emitter resistance to each transistor and also the base stopper resistance.
I am not producing custom designs anymore...if you need/want more power, then i suggest you to search for the Troyan the DHR Turbo or other good power amplifiers offered in this forum...try Mongrel, try Quasi or some Rodd Elliot designs. (ESP pages are very popular)
regards,
Carlos
Old 4th December 2010, 07:33 AM   #1160
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
YouTube - Por que no te callas (cancion)
Max.
The Drek builder's thread cviller Pass Labs 412 25th September 2011 12:25 AM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx amplifier, builder's thread destroyer X Solid State 25 31st May 2009 01:53 AM
Copyright 1999-2017 diyAudio
