Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. - Page 115 - diyAudio
Old 25th November 2010, 01:02 PM   #1141
Mamak is offline Mamak  Malaysia
can dx blame st drive 12" car subwoofer?i want to build diy amplifier and car smps.anybody have suggestion to choose amplifier with high power to drive subwoofer?using 2sc5200 is good choice because this trnstor low price than other
Old 26th November 2010, 03:02 PM   #1142
Larry49 is offline Larry49  Italy
I am using dx st with a homemade car smps given me 35+35 volts and it's sound very good, I did not a test with a subwoofer....
Old 27th November 2010, 03:46 AM   #1143
DX Blame MKII Supercharged i see using mjl4281.that same or not with sc5200?
Old 27th November 2010, 08:35 AM   #1144
Originally Posted by smartx21 View Post
I think you should read and follow this thread:
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!
Max.
smart,for dx blame st, can i parellel output amp to get double power like gainclone lm3886?
Old 27th November 2010, 08:40 AM   #1145
no, the paralleled 3886 can and does give problems if not built accurately.
Your DX st will be less well matched than a pair of 3886.
If you want you can try adding an extra pair of output devices.
But these need to be matched NPN to NPN and PNP to PNP before you build up the single output version.
Adding extra devices does not actually change the power output. Changing the load impedance an/or changing the PSU voltage changes the power output.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th November 2010, 08:45 AM   #1146
these devices are not the same
1943/5200 is 150W and 1A@70Vce
4281/4302 is 230W and 2.3A@70Vce
regards Andrew T.
Old 27th November 2010, 08:57 AM   #1147
so dx blame supercharger cannot using 2sc5200?
Old 27th November 2010, 09:14 AM   #1148
one can use 5200 instead of 4281 but one must accept the limitations of the 5200 and not ask it to do the impossible.
low voltage supply and 4ohm speaker load should be OK.
medium voltage supply and 8ohm speaker load should be OK.
high voltage supply for 5200 is asking for unreliability.
Have you looked at the datasheets for your devices, not just the outputs?
regards Andrew T.
Old 1st December 2010, 08:10 PM   #1149
destroyer X's Avatar
Default I am back home folks....i need some time to read last 15 days posts
2SC5200 can be used Mamak...not the better option, but can be used.
We are having too much of these transistors counterfeit here...i do not know your place if you can have them original, or if you supplier deserves your confidence.
regards,
Carlos
Sorry, Brazil only to be sold... top secret ultimate schematic, not to share...encapsulated VAS:
https://www.youtube.com/watch?v=PHnAky2fV1w
Old 1st December 2010, 09:51 PM   #1150
Uncle Carlos,
It's Great to read your post again.
The Drek builder's thread cviller Pass Labs 412 25th September 2011 12:25 AM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx amplifier, builder's thread destroyer X Solid State 25 31st May 2009 01:53 AM
Copyright 1999-2017 diyAudio
