Old 28th March 2010, 10:12 PM   #1
form109 is offline form109  United States
Default THD Noticable?
we Recently Replaced Our Surround Sound System....the New one is an Improvement Sound Wise,but it is Much Less Flexible than the old one...
the New one uses Molded Speaker Connections which means its almost impossible to replace the current speakers with Aftermarket ones...it also has Less Usable Imputs..1 RCA,1 3,5 MM,and 1 DMPORT...with a Passive sub...Ack.
the Old One Used Standard Speaker Connectors,a LFE Out,about 6 RCA and 1 Digital Imput,and had Individual Adjustments for all the Speakers...as Well as a Variety of Presets.
However the Old One seemed to have a Problem With Distortion....im not sure Excactly to Describe it....its Sort of Like a Raspy Resonance or buzzing..i Tried changing the Speakers and got the Same Net Result...
The System is Rated 0.7 THD...is that Bad?
ive noticed all Speaker Systems Rated around 0.7-0.9 Seem to Distort Annoying on Some Passages Of Sound....not All the Time...but its Noticable on Piano and Ringing or high Frequency Sound Effects.
anybody else notice this?
Old 29th March 2010, 12:58 AM   #2
Gordy is offline Gordy  United Kingdom
It's a difficult call because the '0.7 THD' on its' own means almost nothing. It could be an accurate figure at a certain setting, or it could be just a figure used for their marketing purposes.
Old 29th March 2010, 09:27 PM   #3
can you Measure THD with some sort of Meter?
Old 29th March 2010, 10:09 PM   #4
Yes, distortion meters range from very expensive professional instruments down to PC sound card + free software. If you want to measure actual sound distortion (as opposed to voltage signal distortion) then it becomes more complex as you will need a microphone and possibly some form of preamplifier.
Example sites:
CLIOwin 7
CLIO
ARTA Home
audioTester
E-MU Systems - Established 1971 - Emulator X3, Proteus X2, PCI & USB Audio/MIDI Interfaces/MIDI Controllers
There is plenty of info out there in Google Land, also use the Search facilities on this forum to find threads on this subject.
G.
Old 29th March 2010, 10:44 PM   #5
frugal-phile(tm)
planet10's Avatar
Single number THD is almost completely meaningless in terms of what things sound like. One needs to look at the spectra that the single number was created from to get any idea at all.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
THD distortion HELP!!! nicholas1113 Solid State 20 3rd December 2009 06:21 AM
How do you estimate the thd... dododio Analog Line Level 0 28th December 2006 10:50 PM
Help! Thd + N. mgm2000ro Solid State 5 1st June 2006 12:19 AM
Question about THD boxedin Solid State 5 2nd January 2006 04:21 PM
P-spice THD JensRasmussen Solid State 10 18th October 2002 05:18 AM
Page generated in 0.09378 seconds (73.23% PHP - 26.77% MySQL) with 10 queries
