Old 28th March 2010, 08:09 PM   #1
Default Block negative DC
Hi people,
As some of you may know I'm currently designing a compressor for my final year project at university. I currently have everything designed and tested on a breadboard. It all works perfectly however there is one quick fix I used that needs sorting before I can design the PCB.
The threshold control is simply an op amp in differential configuration. The threshold is controlled via a pot to give a fixed value which is then subtracted from the audio in. This leaves me with the amount of voltage that has crossed the threshold.
The problem I have is that as the op amp is dual DC powered - if the audio is below the level of the threshold I get a negative output voltage. This is undesirable as my design requires any audio below the threshold to give an output of 0V. The 'quick fix' around this that was used for testing was to put a diode on the output of the op amp. When the audio is below the threshold, the negative voltage is blocked by the diode. When it is above, the voltage drop across the diode is added back via another pot on a summing amplifier
The problem is that obviously the voltage drop across the diode varies for different input levels. Is there a circuit I can implement to make up for the varying voltage drop, or is there another way of blocking the negative voltage from the output?
Cheers
Old 28th March 2010, 08:24 PM   #2
AndrewT is online now AndrewT  Scotland
maybe this needs a precision rectifier. An opamp with diodes in the feedback that converts small signal AC to rectified AC ready to be peak sampled or otherwise modified.
regards Andrew T.
Old 28th March 2010, 08:40 PM   #3
Banned
Put the output through a unity-gain follower with a single supply rail.
No, thinking about it you can't exceed the rails on the input.
Andrew is right, a half-wave precision rectifier...
w
Old 28th March 2010, 08:54 PM   #4
The signal begins with a precision rectifier that does as you've suggested. All of the signal being dealt with is positive up until the subtracting amplifier. Here's an example.
The threshold voltage is subtracted from the signal in:
If signal in = 2V and threshold = 1V then the output of the opamp is:
2 - 1 = 1V
If signal in = 1V and the threshold = 2V, then the output is:
1 - 2 = -1V
As you can see, any signal below the threshold will result in a negative voltage. However, in order for the compressor to work these negative voltages must somehow be blocked, or converted to 0V.
I hope this clears the question up!
Old 28th March 2010, 09:03 PM   #5
w
Sorry, Andrew WAS right. I foolishly read his answer and thought of a full wave rectifier. I hadn't thought about using a half wave to block the negative! Such a simple solution too...
Thanks guys!
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 03:48 AM
Soundcraftsmen Amp Negative Volt Reading DC-Offset wingzam Solid State 17 4th December 2008 10:14 PM
DC block before or after power amp? slothlove Parts 2 9th August 2008 11:18 AM
Combined PFC AC/DC & DC/DC SMPS ChocoHolic Power Supplies 33 22nd December 2005 10:04 PM
New amp on a block Peter Daniel Pass Labs 17 2nd May 2002 05:19 AM
Page generated in 0.07986 seconds (83.91% PHP - 16.09% MySQL) with 10 queries
